so my RB20det in my '91 GTS-T idles like it has a gnarly cam in it.
It's not ALWAYS been this bad, its been slowly getting worse. It only idles terribly when its cold. It is also quite hard to start, I have to pedal the gas or try to start it 2-3 times to get going. Under full throttle in first gear, I get a big missfire around 3-4500 rpm, wideband goes full rich. I assume some kind of spark blow out.
Steps taken:
I first assumed the IACV was dead/dirty. Removed that, cleaned it. Re-installed, no change. It does seem to bias idle when the car is nice and hot, however. If i unplug it while running the car tries to die.
TPS is in check.
Put in new spark plugs, gapped to .8mm
Have tried 2 different MAFs, no chance. Timing is set to standard.
My wideband gauge also says it runs super lean at idle (like 18:1 or higher, my AEM gauge only goes to 18)
Ideas? Hidden vacuum leak under intake manifold? Coilpaks gone?
For reference, the car has a stock rb20 engine with:
GTR injectors/resistor
300zx maf
rom tune
fmic/exhaust
rb25 turbo running 13 psi ish
Steps taken:
TPS is in check.
300zx maf
rom tune
fmic/exhaust
