RS*R Exhaust Systems for Skylines!
Direct from Japan! RS*R ExMag GT2 exhaust systems for your Skyline R32. The components are fully polished and made with stainless steel piping. This is a must have performance part for your Skyline!
Maximum power, minimal weight and racecar inspired design have all come together to create the ultimate performance exhaust, the GT2. GT2 exhaust systems are designed with the straightest possible piping route. In some applications, the GT2 will not follow the stock piping route. The straightest piping route will also result in weight savings due to the omitting of useless bends.
The exhaust fumes are expelled from the 101mm tip of the polished SUS 304 stainless steel canister. The GT2 exhaust system also incorporates an innovative slip fit design, where flanges are eliminated, and the pipes are connected with springs instead. By using the slip fit design, clearances are improved and exhaust flow is increased. It is not uncommon to have a GT2 system to weigh up to 30% less than a stock exhaust system.
Application: Skyline R32 (BNR32, HNR32, HCR32)
Dimensions: Downpipe is 70mm - 85mm - 80mm. Catback is 80mm. Exhaust tip diameter is 101mm.
We currently have these components in stock in Toronto.
RS*R ExMag GT2 (Stainless steel) Price: $1275 CDN
RS*R ExMag Downpipe (Stainless steel) Price: $375 CDN
