Hi guys,
Here is engine pricing, please refer to this when purchasing from us. We can get other brands but we usually recommend these and get them the quickest. If you would like another brand let me know and I can price!
- Please contact me for stock checks
- Prices subject to change without notice
- Shipping is extra unless otherwise stated.
- No GST on sale
- Canadian price is an example price, to show rough cost. Proper exchange must be done!
*** Only Skyline applications listed, for other applications please message me.
Payment types accepted: Visa, Mastercard, Debit Interac, Email Money Transfer, Paypal, Wire Transfer, and Certified Check.
- customer must pay all fees associated with the transaction.
Bottom End:
Oil & Water Pump
Tomei Oversize Oil Pump
- THEE best oil pump available for the RB engine
- works on all RB motors
Read what Tomei says: "The RB26DETT engine is often plagued with oil lubrication issues during circuit and drag racing events which are the main causes of most RB26 engine failures. This problem causes the main bearings to abnormally wear out from the lack of oil pressure. The stock pump is not capable of supplying the adequate amount of oil to maintain the right oil pressures at extreme engine speeds that the high powered monster RB26 performance engines require. Another weak point is that the stock pumps gear is made from weak sintered metal and this often breaks when going for bigger power and higher engine speeds and when this little piece gives out can cause an instant loss of your engine. The TOMEI RB26 oil pump has a larger pump gear made of high strength materials to supply a larger flow rate to the engine and it has an external oil pressure adjuster as well."
P/N: 193035
MSRP: $1840.00
GTRC Price: $1564.00
![](http://www.tomei-p.co.jp/_2003web-catalogue/image/pic/P115_01_lube.jpg)
Nissan N1 Oil Pump
GTRC Price: $245.00
![](http://justjap.com/store/images/P/nissann1oilpump.jpg)
Nissan N1 Waterpump
GTRC Price: $215.00
![](http://t3.gstatic.com/images?q=tbn:yjeHrqK5UMu-6M:http://img80.imageshack.us/img80/2811/r34gtrn1waterpump5.jpg&t=1)
Crankshaft:
OEM R34 RB26 Crankshaft with larger crank collar
P/N: 12200-05U03
Price: $775.00
![](http://4.bp.blogspot.com/_AbxJ2bpaLAg/RoAmx3z6kfI/AAAAAAAAA4o/Rr0hUHMGEwQ/s400/ztune05_crankshaft.jpg)
Tomei 8-Counterweight Crankshaft
P/N: 121025
MSRP: $4640.00 USD
GTRC Price: $4099.00
![](http://i1.frsimg.com/images/detailed_images/p67_rb28kit_crank.jpg)
Jdms13rhd Crank Collar
GTRC price: $200 shipped anywhere in Canada
-Made from 4140 High Tensile Steel
-.001 Inch clearance each side
-suited for .002 inch ID crush.
-Full Drive
-Fits OEM, N1 pumps perfectly!
![](http://farm5.static.flickr.com/4049/4580195498_113b1cbda8_b.jpg)
Harmonic Balancer:
ATI 1000HP Super Race Damper
- Eliminates torsional crankshaft vibrations
- Exceeds SFI 18.1 specs
- Laser engraved 360° timing marks
- Black zinc chromate finished
- P/N: 917752 (R32) & 917753 (R33/R34)
MSRP: $650.00 USD
GTRC Price: $499.00
ATI 500HP Super Street Damper
- P/N: 918599 (R32) & 918598 (R33/R34)
MSRP: $575.00
GTRC Price: $475.00
![](http://www.atiracing.com/products/dampers/charts/OEM-honda.jpg)
Pistons:
CP Forged Pistons:
- Any size available
- RB20 Pistons are considered custom, $100 more.
- Dedicated forgings, Fully CNC machined Balanced to + or – 1 gram
- Wrist pins provided at no cost, Pin fitting provided at no cost
- Accumulator Grooves, Dual forced pin oilers, Pick lock grooves
- USA Made
MSRP: $900.00
GTRC Price: $769.00
![](http://www.enjukuracing.com/images/cppistons.png)
Wiseco Forged Pistons
- USA Made
MSRP: $892.00
GTRC Price: $749.00
![](https://www.evo-parts.co.uk/eshop/images/products/Wiseco%20Piston%20set.jpg)
Tomei Cooling Channel Pistons & Titanium Coated Top Rings
- "The ONLY forged pistons on the market that has the cooling channels like as in the OEM pistons. This is our best seller and almost always sold out whenever we get more stocks in. These are the best for endurance and drag racing events. Available in 3 sizes and can be used with our Titanium Coated Top Rings. Also can be used with the standard stroke or with the 2.8L kit."
Piston MSRP: $3470.00
Titanium Top Ring MSRP: $480.00
GTRC Piston Price: $3049.00
GTRC Top Ring Price: $409.00
![](http://www.xs-engineering.com/xsstore/pc/catalog/tomei720_pistonkit_rb26-_492_detail.jpg)
Connecting Rods:
Eagle Specialty H-Beam Connecting Rods
- RB26DETT Only, will need an RB26 crankshaft to use these.
- Weight: 495g /each Journal Size: 1.889/ Length: 4.783/ Pin Size: 0.826
P/N: CRS4783N3D
MSRP: $600.00
GTRC Price: $450.00
![](https://www.horsepowerparts.com/images/products/closeups/EGL/crs5900mb3d.jpg)
Carrillo Connecting Rods (H, A, SA beam)
- Made for RB25 & RB26. RB20 is special order: $100 more.
- Stroker sizes available
- Set balanced to + or – 1 gram, Fully Machined
- Taper or Straight blade
- Available with CARR or WMC fasteners
- Laser Edged, 100% Magnaflux inspected
- Made in USA
Part numbers
Super-A: DA-RB<SA-64783H
H-Beam w/Carr bolts: DA-RB2>-64783S
H-Beam w/WMC bolts: DA-RB2>-64783H
A-Beam: DA-RB-1<A-64783H
MSRP:
Super-A: $1370.42
H-Beam w/Carr bolts: $1908.08
H-Beam w/WMC bolts: $1583.63
A-Beam: $1304.42
GTRC Pricing:
Super-A: $1099.00
H-Beam w/Carr bolts: $1529.00
H-Beam w/WMC bolts: $1266.90
A-Beam: $1049.00
![](http://subzeromotors.com/img/p/741-837-large.jpg)
Engine Bearings:
ACL Race Bearings
- Price includes all Mains, Rods, and the Center Main.
- Standard or Oversize available
- RB30, RB26, RB25 & RB20 available.
* Will update with MSRP and P/N's later.
GTRC Price: $179.00
![](http://atspeedracing.co.uk/products/images/ACL_bearings.jpg)
Nismo Engine Bearings
- 4 different conrod bearing sizes, 7 different main bearing sizes and 7 Center Main bearing sizes for optimum fitment!
- Used on the VRH50A engine in the R391 competing in the 24 hours of Le Mans, the NISMO exclusive surface treatment dramatically increases durability. Can also be use with the RB25 series.
- Seizing load limit: 20% up
- Abrasion resistance: doubled
- Anti-cavitation performance: up 60%
Conrod MSRP: $36.00 per cylinder
Main MSRP: $42.00 per cylinder
Center Main MSRP: $51.50
GTRC Prices:
Conrod: $32.40 per cylinder
Mains: $37.80 per cylinder
Center Main: $46.35
![](http://i1.frsimg.com/images/detailed_images/rb26dett_set12638656154b550f0f584de.jpg)
Power Enterprise F1 Black Metal Bearings
- RB25 & RB26
- Crystallized pyramid shape overlay.
- The crystallized pyramids overlay of POWER F-1 bearing retains more oil on its much larger surface resulting in lower film pressure, lower bearing/journal temperature and help floats the crankshaft centered. It reduces crank shaft temperature by 20 degree C (68 F) lower than any other leading racing bearings.
Conrod MSRP: $324.00 per set
Main MSRP: $360.00 per set
Center Main MSRP: $68.00
GTRC Prices:
Conrod: $291.00 per set
Mains: $324.00 per set
Center Main: $61
![](http://www.powerenterpriseusa.net/products/engine/metal/images/f1%20metal%20structure.jpg)
Stroker Kits:
Tomei RB2.8 Stroker Kit
- Titanium Top Rings are optional
- Cooling Channel Pistons are optional
MSRP (non-cooling pistons): $5690.00
GTRC Price: $5049.00
HKS Step (2) 2.8 Stroker Kit
MSRP: $9920.00
GTRC Price: $8432.00
![](http://www.hioctanedirect.com/images/RB28_kit.jpg)
Cometic Engine Gasket Set
P/N: (RB26) PRO2017A & PRO2017B
Top End: .051” MLS Head Gasket 87MM Bore, MLS Exhaust Manifold Gaskets, Turbo Outlet Gaskets, Throttle Body Gaskets, Intake Manifold Gasket, Idle Air Bypass Gasket, Intake Valve Stem Seals, Exhaust Valve Stem Seals, Cam Seals, Left Valve Cover Gasket, Right Valve Cover Gasket, Turbo flange Gaskets, Eye Bolt Copper Washers, Turbo Air Inlet Gaskets, Eye Bolt Copper Washers, Turbo Oil Inlet Gaskets, Large Fuel Rail O-Rings, Medium Fuel Rail O-Rings, Small Fuel Rail O-Rings, Crank Angle Sensor O-Ring, Engine Temp Sensor/Air Release, Large Eyebolt Washers, Vacuum Tube Chamber Gasket, Recirculation I-Cooler Gasket, Eyebolt Washers
Bottom: Rear Main Seal, Front Crank Seal, Oil Filter Housing Gasket, Oil Pump Mounting Gasket, Oil Strainer Gasket
MSRP: $345.90
GTRC Price: $319.00
![](http://www.spoolimports.com/content/files/Resize%20of%20Resize%20of%20cometic%20rb26%20Top%20End.jpg)
OEM Nissan Gasket Kit
- RB20, RB25 & RB26 available.
GTRC Price: $199.00
![](http://bsp-imports.com/zencart/images/YMGK008-2.jpg)
ARP Headstuds
ARP2000 RB26DETT
P/N: 202-4207
MSRP: $498.00
GTRC Price: $259.00
ARP2000 RB20/RB25
P/N: 202-4301
MSRP: $239.00
GTRC Price: $149.00
ARP L19 Special Order RB26DETT
MSRP: $1250.00
GTRC price: $650.00
- No GST on sale
Bottom End:
Oil & Water Pump
P/N: 193035
MSRP: $1840.00
Nissan N1 Oil Pump
GTRC Price: $245.00
Nissan N1 Waterpump
GTRC Price: $215.00
Crankshaft:
P/N: 12200-05U03
Price: $775.00
P/N: 121025
MSRP: $4640.00 USD
-Full Drive
Harmonic Balancer:
MSRP: $650.00 USD
GTRC Price: $499.00
MSRP: $575.00
GTRC Price: $475.00
Pistons:
CP Forged Pistons:
- USA Made
MSRP: $900.00
GTRC Price: $769.00
- USA Made
MSRP: $892.00
GTRC Price: $749.00
Connecting Rods:
P/N: CRS4783N3D
MSRP: $600.00
GTRC Price: $450.00
- Made in USA
Part numbers
MSRP:
Super-A: $1370.42
A-Beam: $1304.42
GTRC Pricing:
Super-A: $1099.00
A-Beam: $1049.00
Engine Bearings:
ACL Race Bearings
GTRC Price: $179.00
GTRC Prices:
Center Main: $46.35
- RB25 & RB26
GTRC Prices:
Center Main: $61
Stroker Kits:
MSRP: $9920.00
MSRP: $345.90
GTRC Price: $319.00
GTRC Price: $199.00
ARP Headstuds
ARP2000 RB26DETT
P/N: 202-4207
MSRP: $498.00
GTRC Price: $259.00
ARP2000 RB20/RB25
P/N: 202-4301
MSRP: $239.00
GTRC Price: $149.00
MSRP: $1250.00
GTRC price: $650.00
![](https://www.horsepowerparts.com/images/products/closeups/ARP/203-3902.jpg)
