Hey everyone!
Alright i worked on this mostly with Sydneykid from Skyline Austrilia. Im going to put a Hicas Lock bar on my GTR and i wanted to know whats going to happen to the rest of the system mainly the power steering lines. When you remove the rear steering rack there are 2 power steering lines IN and OUT i though i can loop those and everything would be alright. You cant block the lines because it will ruind you power steering pump. You will see what im talking about in the picture below.
![](http://i11.photobucket.com/albums/a155/nanugtr/Civic/attachment-loop.jpg)
Now the picture below will show you where to loop the power steering lines and get rid of all the extra parts you dont need and reduce weight. THe blue dot is where the power steering line goes through the oil cooler system, keep the oil cooler system in the loop, it will help the power steering fluid keep cool. The red dots is where you should loop the power steering lines. This way you will bypasses the HICAS solenoids completely, and you could remove the solenoids which will give you more room to change the oil filter also! hehe... for the people who arent using Oil filter relocation kit!
![](http://i11.photobucket.com/albums/a155/nanugtr/Civic/HICAS_Schematic_Bypass1.jpg)
Im going to add another picture below to show you exacly how the Hicas system is setup under the hood with all the power steering lines, you get a better idea where to loop the power steering lines. And it shows the oil cooler.
![](http://i11.photobucket.com/albums/a155/nanugtr/Civic/HICAS_Schematic_Bypass2.jpg)
Hope this helps.
Here is a link to the Skyline Austrilia form i started!
Hope this helps.
