Wheel Offset and information
This is a sticky topic.
  • Wheel Offset and information
    TAKEN FROM: http://www.usacomp.com/terms.htm
    OFFSET
    The offset of a wheel is the measurement of the hub surface contact area in offset from the center line of the overall rim width of the wheel. A wheel whose hub surface contact area sits further towards the outside of the wheel than the center line has a positive offset. A wheel whose hub surface contact area sits further towards the inside of the wheel than the centerline has a negative offset
    To determine the offset, the wheel must be measured accurately using the following steps:
    (1) measure the overall rim width of the wheel.
    (2) measure the T dimension (Backspace), which is the measurement from the hub surface contact area to the outside of the inner rim.
    (3) divide the overall rim width by 2 which gives you the center line.
    (4) subtract the center line (overall rim width/2) from the T dimension (Backspace).
    (5) a negative answer means the wheel has a negative offset and a positive answer means the wheel has a positive offset
    PCD
    The Pitch Circle Diameter is the diameter of the circumference of the center line of the lug nut holes, this can be four, five or six lug. The easiest way of measuring four or six lug wheels is take the diagonal holes and measure from the outer edge of one hole to the inner edge of the second hole. With five lug wheels this is not possible as there are not diagonal holes, therefore the simplified way would be to measure the outer circumference and inner circumference of the holes. The difference should be divided by two and added onto the smaller circumference or deducted from the larger circumference.
    CENTER BORE
    The center bore is the location hole machined in the center of the wheel and this varies from one vehicle to another. It is essential the wheels purchased have the correct center bore for the vehicle they are to suit, otherwise you may experience balancing problems.
    CALIPER CLEARANCE
    Some vehicles as standard are produced using large brake calipers, therefore our listings have taken this into account when advising fitments. You should advise your wheel supplier if you have modified the brakes on your vehicle.
    Basic Tire Terms
    SECTION WIDTH
    The overall width of the tire from outer sidewall to outer sidewall (tire mounted and inflated but not under load). A section width measurement does not include sidewall protrusions such as raised letters.
    SECTION HEIGHT
    The height of the tire section, from the outer tread surface to the tire bead where it makes contact with the rim seat. Tire is mounted and inflated, but not under load.
    OVERALL WHEEL/TIRE DIAMETER
    The outer diameter of the tire (measured at the center of the tread) while the tire is mounted and inflated, but not loaded.
    ASPECT RATIO
    The relationship of the section height to the section width. Divide the tire’s section height by the tire’s section width, then multiply the result by 100.
    CALCULATING TIRE OVERALL DIAMETER
    Example Tire: 205/45 16
    235= Section width in mm
    45%= Aspect Ratio
    16= Rim Diameter in inches
    (1) Convert Tire Diameter to mm by multiplying by 25.4
    25.4x16=406.4mm
    (2) Calculate section height in mm by multiplying the section width by the aspect ratio
    205x.45= 92.25mm
    (3) Calculate the Overall Diameter by multiplying the section height by 2 and adding that result to the wheel diameter
    (2x92.25)+406.4= 590.9mm
    Marc-André
    _________
    2.2L RB20 GTS-T
    May I add this link to your very useful thread :
    Wheel Offset Calculator | 1010Tires.com is the largest and most trusted online and retail tire company.
    It is a little calculator that may come very useful to get an idea on how your next wheels will fit !
        Just an idea
        People should start posting what kinda of rims and tire size they are running and if it fits with or without spacers.
        Example:
        Running 17 x 8 fronts with +30 offset
        17 x 9 rears with +35 offset
        No spacers or anything fits fine on 1991 GTS-T
        Just to give people and idea of what fits and what doesn't.
          Well.. I still have to make sure my rims will fit and maximum tire width.
          355mm rotors, 6pot rotora, LMGT4 18X9.5 +12, no lower than 2 inches more than stock gtr height. What size of tire would that be?
          No build thread.
          1991 nissan
          El terror
            I'm running 255/40's on 17x9.5 +22 Advans. Tires only rubbed the fender skirts up front when it was lowered 1 inch. Now it's down well over 2 inches (ie: zero gap) and I will need to roll the fenders as the rears contact the top edge of the fender, fronts clear no probs.
            1998 Stagea AutechVersion 260RS
            1991 GTi-R "Angry White Ghost" - FOR SALE
              They rub the inner fender more in the front now since you lowered more? that's the main issue I have with 9.5 rims.
              No build thread.
              1991 nissan
              El terror
                I don't think they rub any more then before, maybe a slightly higher spot. They don't hit the fender in the front at all. Just the rears.
                  what offset should i use for these 18x9.5 all around on my 32 gtr...12 or+15
                    Anyone know if 18X10JJ +12 offset will work on R32GTR?
                    NANU GTR
                      yes, easily
                        Originally posted by LongLiveJDM View Post
                        yes, easily
                        thanks....
                        NANU GTR
                          yes, easily
                          Really? I was thinking about 19x9.5 +12 with a 35 profile rubber but am unsure if it will clear big brakes (which I don't have yet) and I would hate to buy both and not have it all work together.
                          "If we can hit that bull's-eye, the rest of the dominoes will fall like a house of cards...Checkmate." <Zapp Brannigan>
                            I think you would have rubbing problems up front
                              OK whats u guys think of 18X10JJ +18??
                              NANU GTR
