This is a simple how to on installing a 14 inch electrical fan into your R32(or even r33,r34). Most Skylines have the same rad size so here it goes.
1)Remove the rad.
-Remove the rad cap
-Basiclly drain the coolant.(bottom left of the rad)
-Remove the top and bottom hoses
-Remove the Engine fan(4x 10mm bolts) PUT THE BOLTS ON AFTER REMOVING THE MECHANICAL FAN
-Yank the rad out
-Remove the gay Fan shroud.
-Give it a wash while its out
2) installing the fan(mechanical)
Mount the fan in the middle
Locate the stock fan shroud holes on the side of the rad.
Buy a mounting kit or use zip tie or costom make brackets
Install the mount kit on each side
Make sure they are tight. DONT OVER TIGHTEN.
You could also use Brackets from Crappy tire. Make sure it dosent move
Installing the Fan(electrical)
1) Ground the - wire(duh) and splice the + wire into you starter at the fuse box
2) Buy a switch from crappy tire and run the fan to the switch so you could turn it on and off manualy.
Thats it your done.
1)Remove the rad.
-Remove the rad cap
-Yank the rad out
Thats it your done.
