hey guys am just a little curious how if the incress of PSI lvl down, i mean if am running 8PSI and i wanna run more how is it done can any one help me out?
How to??
If you want inexpensive, get the MBC but you will need a new a/m boost gauge since stock will become inaccurate and you dont want to spike due to overboosting. EBC's is the way to go but its expensive. You can get used HKS EVC 4's or older models for like two hundred bucks or so on ebay.
1 bar (14psi) is the maximum I would go given the fact the stock turbos are ceramics and can shear off. A cheap way to get 14 psi, is to cut the yellow restriction band located at the boost soleniod, wouldn't recomend it though.....Originally posted by dasilveira View Posthow much boost you think a stock rb26 engine can go for?? if you dont wanna put to to much money in to it cuz i got a GTR skyline and like right now am running 320hp and i wanna get a single turbo conversion and wanna up the boost to like 14-18psi will i be able??
Rb26 are strong engines cause of the cast iron block and when brand new the internals could support 600hp with no problems but because of the age, mileage of the motor and it depends on the condition of your engine, its hard to say. Compression test is recommended.
You have a GTR correct?
If you have a boost gauge and ONLY if you have a boost gauge, do the following.
Buy one of these. http://cgi.ebay.com/R-Spec-BOOST-CON...3286.m63.l1177
Run hose from both your wastegates and tee them togethor. Run from that "T" to the boost controller, and from there to the manifold.
Start with the boost controller ALL THE WAY OPEN. SloWLY and I mean slowly start tightening it while doing quick spurts on a road to see where your boost is. (this is why you need a boost gauge)
Wind you boost up to no more than 12-14 PSI and leave it a lone.
I ran one of these on my car and it worked like a charm. NO spike, NO creep and spooled up faster than just running off the wastegate (as there is no pressure going to the gate until you reach your set boost, resulting in the gate staying completley closed until then. Normally with a bit of pressure it would start opening and low boost)
TROL
go ask in a supra forum they could tell you thatOriginally posted by dasilveira View Posttell me what kinf of psi can a stock 2JZ twin turbo engine holdundersteer -is when you go off the road and see the tree that kills you
