With Nistune for stock ECU you can run up to 20 gauges at same time on screen via using tablet PC mounted in front of driver as a dash and do changes to maps, etc like a PowerFC hand controller, but in colour and can see the whole map, etc.
It includes knock count (stock ECU has a knock board that filters out engine noise, etc and reports knock), wideband A/F ratio, injector duty cycle, voltage, speed, rpm, MAF voltage, ignition timing, etc. Can change colour of gauges if you get bored.
Mini-Mustang Touch Tablet PC for example with 4x USB ports (one for wideband, one for Consult cable, etc), Windows XP pro, LAN, WiFi, etc-
Only things Nistune can't do at the moment is oil pressure, oil temp, boost pressure like Stack, etc dashes. But those would be simple input mods that could be done later on with software, USB cable, etc or via a few external gauges with peak record, adjustable warning, etc.
Nistune tuning software was designed to be used on a car PC or tablet PC.
