I have a 94 r33 gtst type m just got it dont know anything about it and i looked up how to run the fault codes, the car is loosing boost and power after 5grand dont know what to do ,read the fault codes and it cAme up 34 knock sensor and i thought it was because the intake had come off previously but we put it back on and reset the code and this still comes up i am burning 91 octane what else could this be and how do i check it be descriptive thankssss!!!
KNOCK SENSOR fault code , what can it bee need help asaaaap please
What's your plugs gapped at? If 1.1 you need to regap to 0.8. Have you tested coil packs as well? If not start there and work your way up till u find it.
Oh yea, do some reading. These cars are not for noobs. Try googling the issues and you should find tons of info.
Knock sensors are essentially microphones, any type of detonation will set them off. Spark, fuel, and air are the only things to worry about, make sure all three are good.
Sent from my iPhone using TapatalkLast edited by Voodoo_ChildR32; 05-16-2012, 08:35 PM.1989 R32 Skyline GTR SOLD!!!!
-Bruce Lee
Coil packs are between the valve covers, just remove the center cover and they are underneath. Most cases you use a multi meter to test resistance in the coil. You will need to remove them to test. I forget which pins, there are three, you are basically looking for less than 0.9 ohms. Any higher and the coil is dying. It is also a good opportunity to check your plugs as well. Also take a look at the wiring harness that connects the coils, I have had issues there before. Check the tech sections on the forum here, there are some good "how to's" for figuring out most of the issue you have.
-Bruce Lee
I've run with 91 and 94 and notice no difference except in my wallet. I've even had to run 89 when primo was sold out and been fine. Unless you're leaning out at higher boost, I wouldn't worry too much about fuel.
-Bruce Lee
Knock sensors detect knock. For some reason your engine is knocking, so you're either running lean or your timing is too advanced. Could also be bad gas, but since you already refilled the car, i wouldnt worry about it. Things i would check:
1. See if both knock sensors are plugged in all the way and are not broken
2. Check your timing on idle. I believe rb25 idles around 20 deg btdc. You will need a timing light to do that. If its something like 25 deg or higher, you will need to adjust the Cam Angle Sensor on the front timing cover.
3. If you have diagnostic tools, i would observe the maf voltage when it triggers the code. If it increases smoothly and all of a sudden becomes jumpy, replace the maf.
Then there are more things that other people mentioned already, like coils, plugs, boost/vacuum leaks etc etc..
If you cant do proper tests at home, i would highly suggest to take the car to a shop that works on skylines and know what theyre doing. It will save you time and hassles trying to figure out the problem...
Either way, good luck
Sent from my SGH-I727R using Tapatalk 2
