The gtr i bought failed the out of province inspection because "the brake pads and rotors are too worn." Even though i can lock the brakes up on command...So Im going to use the brake pads off my gtst to make it pass, I heard the rear gtst rotors will fit but the fronts are smaller? Or does anyone in vancouver area have a set a rotors i can buy?!?
Brakes!!
Do you know how they worked that out??? Did it hit the wear markers on brakepads (making a noise), or did they brake test car and it failed on the front wheels???? Or was it just a visual inspection of brake pads and rotors???
300ZX, R32 GTS-T have 280mm front rotors. R32 GTR has 296mm front rotors (same diameter as R33 25T front rotors, but I think different thickness).
Rear rotors should be the same on 300ZX, R32 GTR, R32 GTS-T.RESPONSE MONSTER
Originally posted by Skym View PostDo you know how they worked that out??? Did it hit the wear markers on brakepads (making a noise), or did they brake test car and it failed on the front wheels???? Or was it just a visual inspection of brake pads and rotors???
Rear rotors should be the same on 300ZX, R32 GTR, R32 GTS-T.1991 Skyline R32 GTR
2012 Toyota Tacoma TRD
1993 honda civic b18 turbo
stock GTR front rotors are 32mm thickness when they were new. How much meat you still have??∩___∩
| ノ ヽ
/ ● ● | Hello there!!!
| ( _●_) ミ
彡、 |∪| 、`\
/ __ ヽノ /´> )
(___)f^f^f^f^f^f^f^┐
| | SKYLINE │
| / | For |
| / | Life |
∪ |__________|
1990 HCR32 (Black)
