Hey guys, my 89 r32 ate a ceramic exhaust impeller. When I dissassembled my rb26 the cylinders are scored to badly to be repaired and I also found 7 visual cracks from the head studs to the coolant jackets. It had a balanced rotating assembly, ACL bearings, manley rods and cp pistons. The bearings are all still like new as are the rods and crank. Pistons are obviously junk. I sent my head out but after inspection I found out there is too much ceramic imbedded too deep to be repairable. I have priced options of n1 block, head, and all the other parts that need replacement and am at a point of weighing the options of buying a used rb26 out of an r33 or 34 as it would probably come with trans and lots of odds and ends I could sell to recoup some investment. The pistons, block, head and machine work would be in the same range as buying a used unit. I guess I'm looking for opinions from you guys, and any known very reputable used jdm engine sellers you guys know of. Thanks in advance for any assistance.
Reputable jdm engine sellers
