hey guys, i was the one who started the thread which got carried away 2 weeks ago called: "MAF Vs. MAP - whats better?" anyways i was at a shop last few days and saw a car which really caught my attention.
k so here's the setup.. 2 low mount turbos.. fed by custom made aluminum tube with apexi filters on each end, a rather, "cold air" intake kit setup... after the turbos the air runs through the intercooler.. then back up into the engine bay.. where it meets ONE 300ZX MAF!... then it goes into the standard intake plenum.
this is all controlled by an oem ecu.. heres the kicker.. its not an RB26 ecu.. its an RB25 ecu! tuned using nistune on dyno!
as far as i can see this is ALL advantage with ZERO drawbacks!
advantages:
- ONE big maf instead of 2 small ones
- RB25 ECU is easy to find and cheap to purchase
- MAF benefits of much smoother tuning, and idle, better mapping resolution,
- no issues with Venting to Atmosphere BOV's
- 100% accurate reading of actual air mass regardless of outdoor temp.
- and due to the positioning of the setup.... no concerns about boost leaks!
i can't think of a single draw back... can you!@?
lemme know..
also if any of you have pics of this setup PLEASE put them up.. im dieing for more details on this.
advantages:
lemme know..
