anyone know?
240sx seat rail same as r32?
Boost@14PSI, YellowJacket Coils, Extreme TSC, Full Nismo N1 Bodykit, Greddy Speed Cut Controller, HKS Turbo Timer, 280LPH Denso Fuel Pump, Nismo Slave Cylinder, AMS BOVs, Nismo Clutch Pivot, ACT Xtreme 6 Puck and HDPP, Greddy Panel FilterTags: None
I wouldn't bother, the 240 rails need extensive modification and welding, not worth it in my opinion, just get the proper rails.RightDrive Inc. Parts Manager
Originally posted by plankworx View Postnearly. 240 = one mounting tab is longer than in a 32, can just drill a second hole where needed, in most cases. r32 rail into 240 is gay because you have to weld an extension on. otherwise they are essentially bolt-in, in my experiece91 gtr , 93 rx7 type r and a multicolor 240 スカイライン
Yes and no, one side only one hole is out, the other side three of them are out and the whole thing has to be taken apart and welded. Depending on brand you also end up with a heightened rail as well, meaning the driver is sitting up high.
Proper Bride rails are $220-$280 depending on your car model and seat model. Bride rails can accept Bride, Sparco or Recaro seats. These rails are the proper ones for R32, and require no modifications.RightDrive Inc. Parts Manager
Originally posted by Daryl @ RightDrive View PostYes and no, one side only one hole is out, the other side three of them are out and the whole thing has to be taken apart and welded. Depending on brand you also end up with a heightened rail as well, meaning the driver is sitting up high.
For a pair or each?
Originally posted by Nvdgtr View PostFor a pair or each?RightDrive Inc. Parts Manager
To let everyone know, i bought a set of rails from a 240 at the wreckers i believe it was a 1990. I made my own way of mounting them to my new bride low max seats. I have put the bottom bracket of the seat (w/rails) in my skyline r32 gtr to assure they all fit. Now i have put the seats back together and will install them when i go n take care out of storage. I still have to see how they line up with the peddles n what not but I'm pretty sure they are good. 3 out of 4 holes line up the 4th is the rear outside, you have to drill the hole.
