wann Upgrade to high output alternator
  • wann Upgrade to high output alternator
    So need some advice, With all the electronic in my car the stock alternator is no longer cutting it so i need to upgrade.
    I heard of some guys using nissan quest alternators which have 105 amp output but they are a bit of a PITA to install. Is there another solution or can i give it to a rebuild shop and see if high output components can be installed?
    What are my options?
    Endless-r has high output direct replacement alternators but are very expensive.
      i thought i read somewheres that some infinity alt worked, cant remember which one though
        110amp Nissan Altima alternator -
        nextag.com is available for purchase. Get in touch to discuss the possibilities!
        Needs a custom mounting bracket???
        I think you can upgrade to 120amp for Hitachi alternator when you rebuild alternator -
          ya i would really like this as bolt in as possible, there is no room in the engine bay for me to do any customizing without a major gut job, Unless i find something like the endless for cheap i'll have to see if a rebuild is possible
            I asked an alternator shop and they say they can add like 30amp by rebuilting it. Having a deep cycle battery also help + grounding kit + BIG 3.
              ya i was told that too from a shop in town, it has to get rewound, about a month downtime and 300bucks
