The oil pump issue isn't just the gears and collar. There is a harmonic (or vibration) that naturally occurs in the RB that can rattle the internals of the oil pump as well. I believe they are most predominant at around 3000-3500rpm and 7000-7500rpm. Your best bet is to have the bottom end with the clutch assembly your going to be using balanced and obtain an ATI dampener. The factory nur block or N1 motor is good for 500whp and is still just standard stock internals. The engine comes from the factory balanced with and N1 pump and collar. If built correctly stock internals will do 500whp all day long reliably.
The best pumps to get are,
Tomie
HKS
JUN
NISMO
GREDDY
others...
Tomei and HKS are the beefiest with JUN and nismo being next in line. I have heard of more greddy pumps failing than others but its still really uncommon and is usually the result of something other than the oil pump.
You can also do 500whp for a lot less than 30k... unless your including the car as well :P
Tomie
HKS
JUN
NISMO
GREDDY
others...
I always assumed the harmonics of the RB was related to the common cracks in the block.
