wheel offset issue
    i run 17x9.5 +15 and its pretty flush..had to roll..not pull
      ya, but what tires do you use?
        for all of you keep wondering what offset is good...here 17x9.75 et+25 and im running 25mm spacers all around equals 0 offset on 2.5" drop no rolling fenders and shyte and i did wish i can find a 17x10 0offset wheels or 17x9.5 0 offset to not run stupid spacers
        Toy: BNR32
        DD: R50
          very nice mark, I have a set of 18x9.5 Work CR kais +12 on their way from japan, If needed I will add a 10mm spacer if they arent flush enough. ^^ that looks wicked what size tires are on those wheels of yours?
          1992 Dark Blue Pearl Skyline GTR - 457 rwhp, 404 tq @ 19 psi , chevron 94.
          1991 Gunmetal GTS4 - SOLD
          Originally posted by dah_hunter
          i wait till the lights yellow.. or i lean far and go.. thats what BOOOOST if for..
            yea for gtrs i really prefer something wide and really low offset to poke it out a bit....im running 225/45/17 all around was gonna go 215 but thought it will look stupid and narrow .....yea dood get 10mm spacer or 5mm so u dont need extended studs and poke those rims a bit!
            Toy: BNR32
            DD: R50
              I guess that's OK if you want all the weight of large wheels and NONE of the grip that can come with a 275 tire. I hope you don't get a little crossed up and hit a pothole (or even a nasty crack) in the pavement...........say goodbye to $800 worth of wheel and tire (or your entire car if you really loose it and plow into a pole or a No-Post).
              I really don't know why this is popular, have you ever seen a car running sub 1 min. times at Tsukuba with stretch like that? Not a chance in hell. Unstable, rough as hell, curbage to the max if you screw up (or even parking for crying out loud)..........rock on.
                ^^ I'm in your camp... my 17x9 +27 and 255 tire fit very nicely, thank you very much!
                  its my car i can run it over a pot hole and its none of ur business...this to show ppl here the idea of having a low offset wheels with a help of spacers...
                  ps there is no tsukuba here in vancouver so what your saying dont matter i will rock on
                  Toy: BNR32
                  DD: R50
                    I had 18x9.5 +25 on the back of my gts. fit really good. Now my car is running 17x9 +12 and they fit too.
                    This is with just rolled fenders. No widening (pulling) of the fenders was done.
                    It really really really depends on the look you are going for. I cannot stress this enough.
                    Tell me what look you are going for. To me. It looks like you are just for a "better than stock" look. It sounds like you don't want to stretch tires, or do any fender modifications. To me a +17 would be ideal. A little camber, a little stretch and a little low. DONE.
                    But if you don't have multilink suspension and you can't dial in camber. And you want the widest tires possible. Get the +27. Then you can get some nice size rubber on there and be on your way
                    And to Jon. To each his own. To some its style. No one said anything about doing a 1 minute lap at some track
                    The reason most people go wide wheels is for the dish. the wider the wheel the more dish you can have.
                    Yeah i run a 18x9.5 with a 225/40 and a 18x9 with a 215/35. I like my car low and wide and i daily drive it without a problem
                    No arguments starting here. Just keep your style to your own car and ignore the ones you dislike. Simple as that. No need for bashing.
                    Originally posted by m_melen
                      stretching is for volkswagens
                        cool story bro.
                        if your not going to help the OP. why post?
                          ^ THIS.
                          Check out the Wheel fitment thread in the GTS Discussion section.
                          I think BurlyR32 had some pics of 17x9 +20 with rolled fenders which is close to the +17 offset you're considering.
                          For the other size, search for someone with r33 gtr wheels on gtst. r33 gtr wheels are 17x9 +30.
                          I plan on fitting 18x9.5 +15 once my coilovers show up.
                            THANK YOU.
                            NOT everyone has the same goals with there car and not everyone wants the same thing.
                            If i was the OP. I would get the +27. Only because you can add spacers to lower the offset. But if you get +17 you can't raise the offset.
                            • #29
                              simplicity
                              Toy: BNR32
                              DD: R50
