Edit: Found a loose ground right above my turbo, does anyone know where it is supposed to go? I connected it to one of the allen bolts that hold the [24 valve] cover.
Alright so after messing with the coilpacks/wiring etc just all the electrical.. i am starting to wonder if its fuel. When the car starts missing for more than just a couple seconds, i get a strong fuel smell and when the cylinder picks up again, usually get a back fire. I am starting to wonder if i have an injector sticking open? Also somewhere by the intake plenum, sounds like under it by the injectors, when i turn on the power to the car i hear a faint kind of hum/hiss while the system is priming, it lasts for about 5 seconds then the sounds fades. While starting the car i can hear the miss, and while the car is running down under the intake plenum i can hear like a ticking/knocking sort of sound. Almost sounds like electrical sparking. Every time it makes the ticking/sparking sound the engine idle drops and has what sounds like a misfire. I will have a video up shortly, the first hiss while the system primes can barely be heard, theres a louder hiss for a second then the faint faint hiss can barely be heard after. Once the engine starts the ticking/knocking is fairly noticeable. Can anyone tell me if this sounds normal or if it sounds like the cause of my random misfires and cylinder shutting down while driving. And if its the cause of this, is it an injector?
