Who's got HSD's mine knock over bumps. Do yours?
  • Who's got HSD's mine knock over bumps. Do yours?
    HSD suspension. These are my first set of coilovers. I was looking for a good set of affordable street suspension.
    Unfortunately I don't think they where installed correctly. Or are all coilovers noisy over bumps?
    I watched the install video's a few times. I believe I can handle adjusting them.
    maybe the springs are loose, its also too low for street,, I could be rubbing.
    any suggestions?
    1993 GTR
    1992 GTS-T Type - M (Sold)
    try adjusting the pre-load on the spring a little bit tighter. that should help
    1990 Mazda Manyata (Turbo Miata 6psi 175whp 172wtq)
    1991 Nissan Skyline GTR (13.5psi estimate of 320whp)
      yes mine do. just the driver side front. Its really annoying im gonna take it apart and make sure everything is clean and tight like a tiger,
      Jordie Lewis
      1993 Skyline Type M
        Is the ride stiff? Have you checked for any rubbing? I recall a similar noise from my suspension and I just adjusted the dampers.
        1989 R32 GTS-t (Sold)
          Shouldn't knock over bumps...check out the install and see if anything is amiss. It could also be the upper links, they will knock over bumps if they are done.
          RightDrive Inc. Parts Manager
            What Daryl said, sounds like your FUCAs. Buddy of mine has really stiff coils and has replaced bushings or anything like that.
            I think the stiff coils didn't make it any easyier on the car or fucas/ rest of suspension.
            92 Gtst/Silver bullet
              I had HSD 12/10s and now I have 8/6s. Both sets knocked until I did what Daryl said.. Did both of them last year and no more knocks on bumps!
                No knocking on mine, most likely follow advice above. Sway bar end links can cause this problem even though they feel tight. I went through this with a Maxima and my wifes Escape.
                  there should be no sound,
                  granted one should expect not the most controlled quality build for the price.
                  but i mean im sure you can take it a part and just put it back together better then from factory.
                  coilovers are very simple.
                    I have stance coil overs which are basically HSD. One thing I will stress is that you raise the car up, removing weight of the coilover, and make sure the car isn't lowered by drooping the spring and that it is lowered by the bottom of the shock mount. By drooping the spring rate you are effectively saying goodbye to any performance so when you hit a bump the spring has much more movement that if you have it lowered by the base with a helper spring in-between.
                      thanks
                      Great advice.
                      I rented my buddy's hoist today. Raised the front a bit. The back are the ones knocking. I tightened the springs a bit more.
                      still knocking. I am thinking upper link like Daryl said.
                      I'll have to order a set off you.
                      Do I need a press to install them?
                      Do you have a pix of the part your talking about.
                      1993 GTR
                        I have a cheaper fix for you. I have used but not knocking or shot Rear upper control arms. 75$ Shipped
                          I think we all are missing the important part here.
                          They are knocking because the top pillow ball section is not high quality. Honestly, for any cheap suspension out there, the first thing to let go is the top pillow ball mount. Second, top neoprene o-ring seal gets ripped, then oil spits out. And on and on...
                          9/10 the ball mounted inside the sandwhich plate is not chromoly steel, just some cheap arse alloy that is probably not even round to begin with lol
                          You could try and tight the top nut down a bit, best done with suspension out of the car, but you are really only suppose to tighten a little, otherwise the top will bind up and wear out even quicker.
                          Tein SS (bottom grade) from years ago had this same trouble. I brought it up to a Tein official year or so at a trade show and they admitted there was indeed trouble years ago but the later equipment all corrected.
                            Originally posted by support@feastauto View Post
                            The top pillow ball section is not high quality. Honestly, for any cheap suspension out there, the first thing to let go is the top pillow ball mount. Second, top neoprene o-ring seal gets ripped, then oil spits out. And on and on...
                            Are you HSD coilovers specifically aren't high quality or just general low priced coilovers? I thought the HT with the oil coolers looked pretty premium but haven't seen any comparisons online and have been wondering if they even hold a candle to Apexi, Aragosta, KTS or Ohlins coilovers? (Nottrying to thread jack! :P)
                            Double track drift, yo.
                            (oo sκylιnε oo)
                              My personal belief on the pillow ball problem is based on feedback from customers and how they describe it. As I said 9/10 its the pillow ball rattling within the plate socket.
                              Here is good example of a really well used set off S13 coilovers with warn pillow balls. Literally grooves put into the ball section as seen.
                              With this set put back together, the camber plate moved around with out much resistance. On the road it would have been knocking like mad.
                              For the HSD's in question, if you were to disassemble the top end of the suspension, I suggest cleaning up the ball & socket area and before resembling, squeeze some heavy duty bearing grease to really lubricate the joint, then reassemble.
                              And guys lets be real honest here, within the last couple years, there has been so many re-branded suspension kits put on the market its not funny. Sure, the damper quality may be pretty good, but the rest is not top quality.
