Hey, so here is my dilemma today: after I romp on it a bit and come up to a light my cars idle tends to drop really low then come back up. And before a changed a vacuum hose my car has actually stalled before.... And as its it's idle, she's sort of rough. My "mechanic" seems to think it could be my timing or my need for a proper BOV, but I doubt him sometimes. Lemme know what you think??
Idle crash after Punching it.
First, what do you mean by "need a proper bov"? What bov are you running? Does your bov vent to atmosphere? If so, then your "mechanic" is right.
That stalling is caused by your maf calculating a quantity of air that isnt there because your bov let it out. Recirculating your bov will solve this.I canz take this corner at 195k cause i gots AWDZ. Get real.
exactlyOriginally posted by danwit View PostFirst, what do you mean by "need a proper bov"? What bov are you running? Does your bov vent to atmosphere? If so, then your "mechanic" is right.
or getting the ECU re-tuned for vented BOVs
Hey I might have the same problem. I've changed the cams and the bov's for atmospheric. I have some up an down on my idle. I know i have to tune it but i wanted to make sure it's not a bigger problem...
So a tune up would probably solve everything....?My sky got 99 problems but to find bitches ain't one
I have the same problem as well, and I have cams as well, going to get a tune.Originally posted by Fred-R View PostHey I might have the same problem. I've changed the cams and the bov's for atmospheric. I have some up an down on my idle. I know i have to tune it but i wanted to make sure it's not a bigger problem...
So a tune up would probably solve everything....?"Syntax with a steering wheel."
Volkswagen R32 Daily
Nissan R32 Skyline Summer Car
search guys... after a 5 second google search i found this.
plus the other thousand links that pop up.- Adam
