So I recently picked up a 1996 GTS-T. Today when I was making a u-turn in 2nd gear the car randomly shut off, could it be a stall? I was pretty low rpm but didnt seem that low enough to stall it. What rpm would stall the car in 2nd gear? It was very odd and that's all I could really think of that might have happened. Thanks in advance
Am I crazy? Little help
I think there's 2x different TPS setups on RB25DET. One is using a piece of metal inside TPS for idle contact (can bend over time and used on R32 and I think Series 1 R33 RB25DET) and another type of TPS that uses a voltage for idle contact, which was the solution to the idle contact bending problem (Series 2 R33 RB25DET, R34 NEO RB25DET).
TPS is mounted on side of throttlebody and helps ECU with transient throttle enrichment (electronic version of a accelerator pump if are used to carb engines) and when to kick rpm up (idle contact) to stop engine from stalling when backing off throttle (when to select kickdown tables on ECU that kicks rpm up), etc (affect's many features on ECU).
Normally would be checked, adjusted with Nissan's Consult or Nistune tuning software (light's up in software with Nistune or on Consult screen telling you TPS is touching idle contact).Last edited by Skym; 06-21-2013, 12:34 PM.RESPONSE MONSTER
i think your problem is your u-turn in second gear needed to be more of a 6500rpm u turn if you catch my drift
just kidding but check your tps if you need one i think ive got a spare.1989 Gts-T Sold
1992 GT-R Sold
1991 Gts-T Sold
1989 Gts-T Sold
Haha, shes my baby still ill be getting to that later maybe.Originally posted by GTS-James View Posti think your problem is your u-turn in second gear needed to be more of a 6500rpm u turn if you catch my drift
just kidding but check your tps if you need one i think ive got a spare.1996 Skyline GTS-25T
Thanks ill check it out. Its been raining for days so im waiting for it to settle, dont want to stand out in the middle of the rain :POriginally posted by Skym View PostI think there's 2x different TPS setups on RB25DET. One is using a piece of metal inside TPS for idle contact (can bend over time and used on R32 and I think Series 1 R33 RB25DET) and another type of TPS that uses a voltage for idle contact, which was the solution to the idle contact bending problem (Series 2 R33 RB25DET, R34 NEO RB25DET).
Normally would be checked, adjusted with Nissan's Consult or Nistune tuning software (light's up in software with Nistune or on Consult screen telling you TPS is touching idle contact).1996 Skyline GTS-25T
