Im having a stalling problem with my RB26 and wanted to get you guy's insight. Car runs
fine on the road and freeway, but stalls at certain times. When I turn the car on (cold start) engine starts only to stall out unless i give it some gas once it turns over. After manually giving it gas to prevent it from stalling it idles as supposed to (does have a slight rough idle that bounces up and down 100-200 RPMS). When running, engine does idle when coming to a stop. However, after running it hard, it stalls out once i left off the throttle and put in neutral. Ive look around and found that it could possibly be a throttle position sensor or a mass airflow sensor. I would appreciate the help before i start replacing things that dont need to be replaced. could it be a TPS or MAF??
Thanks in advance
Thanks in advance
