That filter state its for Model 9810- R34 assuming its October 1998 on ward?, Mine Was manufactured in June 1998. Will this fit? Been reading about it and I am getting confuse, others will say 15208-53J0A will fit on all R34, some will say the opposite, which is it? can i get a clarification please and thanks
Nissan Oil filter 15208-53J0A
I believe the filter matches for all RB and also 300zx. On my may built r34 I used K&N HP-2008. those were on sale at Can tire out here this week actually :P.
Other filters that are of good quality, and will be a direct fit; Purolator PureOne PL24457 , Mobil1 M1-208
Those 3 i listed are great choices. But if you just need whatever is cheap and good ( napa gold? ) , lookup via Nissan 300ZX TT ( 1990-1996 )
perhaps just nissan just updated their filter model as the years went on. the size stayed the same from r32's to r34.(O||o___SKYLINE___o||O)
I'm thinkin' RB's
Originally posted by jesusjuice View PostI believe the filter matches for all RB and also 300zx. On my may built r34 I used K&N HP-2008. those were on sale at Can tire out here this week actually :P.
perhaps just nissan just updated their filter model as the years went on. the size stayed the same from r32's to r34.Last edited by 403SKYLINEGTT; 03-24-2014, 10:43 PM.
1008 could fit the threads, but is a smaller filter than the 2008.
2008 was the fitment for many 90s nissans, and the 1008 was more of a toyota/subaru fitment if i recall. Though it was used on the newer 350z, murano, s14 and s15.
Nissan oem has had some bad reviews, though many car products have mixed reviews, take it with a grain of salt.
I have used all 3 of the filters mentioned for RB25's, and they fit perfectly and did a good job.
PL24457
m1-208
hp-2008
@ Rvander - consider the 2008, if you can spare the 10$ just to see, r32-r34 sizes were the same. black and white the larger filter will have more capacity ( and better flow? ).
The fairlady z32 ( VG30DETT ) and both the RB26 and 25 have the exact same size. Any dealer or parts store locally will have a database, and whatever filter fits the z32 TT, will be the direct fit. Only thing to really choose here is brand.
Napa gold for value, K&N for performance, Pureone for filtration ( these are my opinions )
While we are on this note, @403, what oil do you use?
if you need to research what size was designed for what, look @ this chart here - http://www.nismo.co.jp/products/cata...x.html#page=35
On the 2nd page, RN011 = HP-1008 , and RN021 = HP-2008
All skylines have this RN021 = HP-2008
Hope this helps! i remember stressing about this before too :PLast edited by jesusjuice; 03-25-2014, 12:24 AM.(O||o___SKYLINE___o||O)
I'm thinkin' RB's
Originally posted by jesusjuice View Post1008 could fit the threads, but is a smaller filter than the 2008.
PL24457
m1-208
hp-2008
Hope this helps! i remember stressing about this before too :PLast edited by 403SKYLINEGTT; 03-25-2014, 12:54 AM.
10w50 is too thick, the engine was only designed to pump and flow a 30 or 40. 30 for a "virgin engine" ( healthy grocery getter ), or 40 for spirited use.
Oils have evolved much in the last amount of years, and a 5w is now recommended by nissan even for the older 90's engines. however this is completely up to the owner.
Mobil1 should be ok. If you are near a canadian tire they should have shell rotella T6, which would serve a skyline much better in many regards.
5 or 10W & 30 or 40
If you want something "in between" , head up for an Acea a3/b3 oil as they are usually on the thick side of 5 and the thin side of the 40, if that makes sense
( maybe its like a 7w36 haah! )
Trust me on the Rotella T6 5w40 if you have time to grab some before you have to change up. Its usually 35$ and will help better than M1 in the cold, AND it can handle the heat of the turbo.Last edited by jesusjuice; 03-25-2014, 01:24 AM.(O||o___SKYLINE___o||O)
I'm thinkin' RB's
Originally posted by jesusjuice View Post10w50 is too thick, the engine was only designed to pump and flow a 30 or 40. 30 for a "virgin engine" ( healthy grocery getter ), or 40 for spirited use.
5 or 10W & 30 or 40
I just got HP 2008 K&N from can tire,they don't have in stock,but can order,takes one day,i think it was like 17$,did not fit it yet,car still in storage,i used Motul 5w40 for the past couple years,but going to try Castrol edge Syntec 5w40 this time.Skyline GTR R33
5 or 10W & 30 or 40
Pure internet myth. Truth fully the best oil for the winter? with actual scientific proof and not unfounded bias?
Any synthetic 0w30 or 040
It's hard to beat Baldwin filters. something like 12 micron ABSOLUTE and high flowing. Much better than the AMSoil, purlolator, napa gold, mobil 1, hks and so on. That and they cost like $15 at most. They use these everywhere in the industrial plants so they don't need to mark up like HKS filters (which don't filter that well).No build thread.
1991 nissan
El terror
Originally posted by turdzoplenty View PostAND it has the completely wrong additive package and designation for high revving hot running gasoline engines.
Though, if you do have compelling arguments for me to stop using it and prevent damage, I'd be grateful. My ideal oil was Motul 8100 and Mobil 1 30 weight served me well in the past, so I'd be ok with absorbing the higher costs for peace of mind.
EDIT: Just to add to your comment, I agree that 0 cold weight is better for winters (the lower is better). The problem is in the addtives needed to achieve the lower friction; they burn up easily, reducing the overall quality of the oil IIRC. So when running hot or for extended period (or in the summer), you're better off at 5 or 10 cold weight for durability.
Originally posted by Bruizer View PostIt's hard to beat Baldwin filters. something like 12 micron ABSOLUTE and high flowing. Much better than the AMSoil, purlolator, napa gold, mobil 1, hks and so on. That and they cost like $15 at most. They use these everywhere in the industrial plants so they don't need to mark up like HKS filters (which don't filter that well).Last edited by MarusGTR; 03-29-2014, 10:37 PM.1992 BNR32 SKYLINE GTR
