92 GTS-4, car is very clean underneath, barely 100K on it. But every time I fill it completely, or take a really hard left, I loose gas, right about where the filler neck meets the tank. I haven't yet dropped the tank to see what the problem is, I was wondering if this is a common problem and what it is before I get into it. The car rarely smells of gas, even when sitting in a garage. I was thinking maybe the gasket that seals the filler neck to the tank is deteriorated? I can't imagine the tank is rusting out since the car is so clean. Anyone have any guesses? Thanks guys!
Gas Tank Leak
There is a rubber coupler that attaches the neck to the tank, that is probably cracked or the clamp isn't tight enough. Take the right wheel off, take off the cover in the fender well covering the neck and inspect.“Hey, come on, its a car right? No. It’s a symbol of your history, its a thread of continuity from which you came to where you are. It’s important that you don’t want to forget who you are.” -Dr.Phil in "Love the Beast"
I had that in my r32 gts, it was the o ring between the filler neck and tank. I put Some quick seal one o ring too, hasnt leaked since. I didnt drop the tank either, Hope that helps."Syntax with a steering wheel."
Volkswagen R32 Daily
Nissan R32 Skyline Summer Car
