With the snow flying, it's become rather apparent that my ABS doesn't work. But my AWD does. Does it not use the same wheels speed sensors for both? How can I have one and not the other? As best I can tell, everything ABS related is plugged in.
ABS Independent of AWD?
Your abs unit is separate from the attessa. You most likely have a abs pump fault rather than the wheel speed sensor faults your thinking of“Hey, come on, its a car right? No. It’s a symbol of your history, its a thread of continuity from which you came to where you are. It’s important that you don’t want to forget who you are.” -Dr.Phil in "Love the Beast"
Havent had my car on in years or fault diagnosed but there should be something in the manual. As far as i remember your control unit is all incorporated with the pump, no remote control modules etc. You could be lucky and just have a blown fuse/relay. Best to start checking the basics (power and ground) and going from there.“Hey, come on, its a car right? No. It’s a symbol of your history, its a thread of continuity from which you came to where you are. It’s important that you don’t want to forget who you are.” -Dr.Phil in "Love the Beast"
