Hey guys,
I just spoke with my mechanic and we had a few ''disagrement'' on a few stuff so I'm curious what other would do in my situation or if you already tried it and could give your input.
Basicly, the build is a RB26 with a EFR 83/74 EWG plumb back with Type-R cam and all the usual add-ons.
Car will be daily driven in downtown commute.
1) Spark plug, I wanted to go NGK BKR7E-11 and he told me it might not be enough. I believe he was talking about enought cold.
2) Oil pump ; I wanted to go stock pump 81mm with reimax gear locktite the plate and shim the pressure relief. He prefer I go with a nismo,reimax or tomei pump.. but then.. you need bigger sump, so he tell me to get the greddy.. then why not do a drain back with hose..
I agree it might be the best thing to do, but at 3000$ more, I'm not sure it's needed for a daily driven downtown commute car that will barley do any drag and circuit stuff. I'M pretty sure the reimax gear can handle my type of driving. Also, I don't like the gredyd extended pan, i'm scared to break it when hitting pothole ( I live in a winter country)
3) Injector, I want to go ID1000 with stock fuel rail and my actual walbro 450lph . he recommanded me to go twin 044 pump, surge tank with lines and custom rail.. I honestly think it's over-rated for my application. I was doing 570whp with sard 700cc and stock setup with nismo fuel reg..Surely, I could strech an extra 75-100whp with this kind of setup with bette rinjector. Whats your thought ?? ON top, I don't really have space in my trunk for that kind of setup.
4) I wanted to go with the hi-octaine air/oil separator to free up some space in my engine bay. would you feel confident just running this setup with a mines cam baffle or would you still run an external (vent to atmo) catch-can ?
5) Finally, I used to run a 3 inch exhaust and made 570 with a pair of -5s. It seems to be breathing nicely. My setup was ; Vibrant ultra quiet resonator, magnaflow 3 inch straight pipe muffler with a Varex muffler 3 inch.
Because I do downtown driving, I like a ''quiet exhaust''. So this time I decided to go 4 inch muffler as a cat-replacement, with a HKS Hyper 90mm rear muffler + a 90mm varex. He scared it might be too restrictive.. saying I should remove one muffler and only run 2. Or maybe I could run 2 + a resonator. He said, every muffler you add, you restrict the flow by about 100whp.
6) Also wanted a 4 inch dump pipe considering I was going to plumb back my EWG. First, he dont like the idea of plumb back the EWG, but I'm scared I will hate the loud sound of the EWG. Surely, a few of you must 've drove a EWG setup, how was it ?
Thanks for your help, will report back with result for everyone wondering
