Some of you may know that I am selling my rolled gtr.
Since the body is no good, but most of the drive train & engine had no damage, basically that is what I'm selling.
I had some guys come by and do a compression test.
But they did a few things that I thought were weird.
Just note I had not started the car for a while and the battery is weak.
1. When doing the compression test, they did not have the throttle open.
2. They did not hook up the battery to a power source.
3. The test was done cold and not warm.
The numbers came out to be about 140 on four cylinders and about 130 on two (it was read out loud).
Since the compression should be at closer to 170 they want cheaper.
But I had never seen a compression test done in this way and I was under the impression that if done properly, compression should be above 150 not 170.
There were several other points that I thought strange about the buyer, but keeping that aside, this compression test is not normal.
I don't have a tester, but have seen it done many times.
I just need to check in with others about this since I don't have a good feeling about it.
If the buyer is browsing around and sees this thread, feel free to comment.
