Originally posted by tokes
View Post
Best Option To Reach Reliable 450-500 HP
1998 Stagea AutechVersion 260RS
1991 GTi-R "Angry White Ghost" - FOR SALE
Originally posted by tokes View PostFrom a theoretical engineering standpoint a single will be better, and I can't see how a set of cast 18 year old manifolds with T25 housings and a compromised, awkward downpipe design is going to perform better than a properly matched single on a divided manifold with a merge collector, and a good smooth downpipe.
You can bolt on a pair of 2530's, some minor exhaust manifold porting, downpipe, low lift/duration cams, intercooler, exhaust, supporting fuel system mods, and good ECU and with good tuning and pump gas, do anywhere from 470-510whp (depending on engine health) reliably. We've done it at least 30 times. I believe going for 500ish with 2530's is cheaper than a single - unless you go for the ebay made in China crap that will fall apart in 3 days.Eric Hsu
motoIQ.com
Guys I only have 8grand aside right now for this build, So it looks like Im waiting till next winter.....
Someone mcfly,wingnut,eric , write up a quick build sheet for reliable 500 hp @ 10-15g if possiable. It wouldnt only benifit me, but all the other ppl thinking about doing the same
that would help me out alot
I don't have an exact list spelled out, but you can check this car out here:
BNR34
This car is a relatively simple set up with all the correct parts and proper tuning. You won't need the extensive head work or billet camshafts for your goals. Several people on Fresh Alloy have used this car as their target for their build.Eric Hsu
motoIQ.com
But that is a newer R34 without the oil drive problems like on our early model R32's. I think you could do it on an 8K budget, rebuild the motor with forged pistons, a crank collar, and mostly OEM other stuff. That way you know its fresh and built right and not going to crack a ringland. Add some 2860R low mounts, elbows/downpipes, PFC, Z32 MAF's, some bigger injectors and a walbro 255HP in-tank and I think you could pull it off with an 8000 dollar budget.1990 Skyline GT-R - Jet Silver Metallic
It'll run someday
There are no oil pump drive problems on a BNR32 if you keep the revs below 7500 on a street car. Occasional track days are fine on street tires. Anything sticker than street tires and you'll need oil baffling improvements. A good tuner can make the 470-510whp at 7500.
Sponsors? Don't we all need them.....Eric Hsu
motoIQ.com
Originally posted by Lookn4aGTR View PostEric you could be one....
XS - Canada... lol
Originally posted by mcflyI had pitched that one in the pastEric Hsu
motoIQ.com
Well guys.. I was going to slap gt2860rs on and take care of the fueling and cooling and just keep the boost at .7 bar. And then have a spare engine block and oil pan etc, and build that up until its complete, and then swap into the car... but I've decided to keep it at its current specs for another year and then decide from there
thats my update
Peter
:drive:
