You might think I just hit my head...because this even sounds a little odd to me, now that I am actually typing it. There are quite a few custom setups that use supplimentary injection in similar ways.
Why couldn't one tune with a '7th' Injector firing at the inlet of the Plenum on an OEM "bung'd" Intake Manifold to help out (a bit) with the lean condition and 'stacked up air' that is experienced by Cylinder #6 in an RB26 using an OEM manifold ? (rather than just richening #6 only)....
Anyone with an aftermarket ECU that has a spare driver could accomplish this.....right ?
Additional Injector Driver capable ECU, plus, maybe something like a single 440cc OEM injector (since they are always readilly available) ?. Just something to help even things out a bit ?
I realize this is probably completely retarded sounding, as you might as well just tune #6 richer to compensate (as you will need to anyways).
BUT, could this have any positive affect on things ? at all ?
If budget doesn't allow you to run a proper Plenum, something like this could be better than nothing at all, no ?
