GTR door side impact beam.
  • C-unit
    replied
    No..I am not doing the cage myself. I am getting my fabricator to do it. I want to keep as many interior pcs as possible. I think from where I am going, I need to trim the door panel a little bit.
  • FormerVDubber
    replied
    Originally posted by Oakville View Post
    Are you doing this cage yourself? and the way im thinking right now, youre removing the lower door card and having a few bars run between you and the door skin? or am I way off... im just thinking of my friends sti track car..
    I dunno about C-unit but thats more or less what I'm doing except the cage. I'll be having that done by someone else
  • Oakville
    replied
  • C-unit
    replied
    I am planning to remain the power lock, power window and the stock door panel. I am thinking for the all that work..might as well just swap new doors right??
  • FormerVDubber
    replied
    Originally posted by C-unit View Post
    sorry one more questions..will that apply with GTS-T as well?? Just incase pre 91-sept doors are hard to come by, maybe I can use the GTS-t ones.
    Why not just gut the existing doors? If your putting in a proper cage in anyways, you can just cut away all the crap you don't need on the doors you have...That's what I'm going to do.
    I have allready eliminated power locks, speekers and related wiring. I have also relocated the window switch to the center consol and I'll be making a new interior panel from an aluminum sheet. Once my cage is fabricated I'll be cutting away and drilling "speed holes" in the hidden door structure.
  • JROY500
    replied
    Hi,
    how can I know the fabrication month of my gtr?? its not write on the blue plate in the engine bay..
  • Daryl @ RightDrive
    replied
    Sorry, don't know if it applies to GTS-T as well
  • C-unit
    replied
  • Velders
    replied
    Never mind go with what Daryl says, shows what I know lol
    replied
    Side impact beams were included from Sept 1991 onwards
  • C-unit
    started a topic GTR door side impact beam.
    I was told that the later model GTR has the side impact beam in the door and I have some questions regarding it.
    - When does the Side impact beam become std on GTR?
    - How much does it weight compare to the one w/o the beam?
    I have a 93 one and I am sure it has the side impact beam. Since I am going to get a cage with door bar, I am looking for doors w/o the beam to reduce some weight.
    *FRP is good choice but I have fiberglass waves..
