Originally posted by cobrAA
View Post
Single or Twin plate clutch for drag ?
Good choices
RightDrive Inc. Parts Manager
your right, nismo never made a master.Originally posted by Daryl @ TunerLab.jp View PostThere is no such thing as a Nismo master.
You don't "need" the Nismo slave, some people use it if they are using a metal plate clutch. Just like some people use stainless lines, you don't "need" them, but some people use them.
If you want to just change your factory clutch to a metal plate, there's no problem with that.
Kudos Motorsports
Somes said the nismo slave put too much stress on the master ( something along those lines)Need detailing done to your car? I'm open to travel to detail your car :
Nismo slave has a larger effective area so for a given load actuation pressure is lower and required volume is higher than OE. This results in less clutch effort and greater travel.
AM clutch usabilty typically benefits from this change.
Dansigpic
The Beaumont Connection
