Just put in garret 2860-5 turbos . have a problem.
  • Just put in garret 2860-5 turbos . have a problem.
    The dam factory dump pipes flanges are diffrent from the garrett's. The bolt holes don't even line up. WTF?
    Are they .63 a/r?
      You may have wrong turbine housing on your turbo. A picture of the turbine housing on your new turbo would help to ID what's wrong.
        Mine fit perfectly with both the tomei dumps and stock dumps.
          The oil return holes have to be reamed inward to work same as mine
            It's possible you bought the wrong turbos. the GTS using a different exhaust housing than the compact 5 bolt used on a GTR. It's been known that people buy the cheaper turbos but get stuck with the wrong housings... the only mod I needed to do was the oil return and oil feed reducer.
            lol
              Originally posted by Super_Dude View Post
              Are they .63 a/r?
              I have the .82ar.
                turbine A/R should be .64 however there is an option for larger A/R.
                lol
                  problem is i had the wrong ar hot housing. fixed.
                    .82 AR will make your car very laggy. I would do max .64 on stock displacement. And you probably got the ones that are meant for SR20.
                    10 Infiniti FX35
                    09 Infiniti G37X coupe
                    02 Subaru WRX....sold
                    01 VW jetta 1.8T....sold
                    90-00-08 BNR32
                    92 NX2000...sold
                    95 S14 LE...Sold
                      I love lag, it's the calm before the storm. I wouldn't want it any other way, you can cruise around under 4000rpm and get 25mpg (which I do), then beat the living tar out of a ZR1 when you get up on the meaty part of the boost. I make 3-4 lbs at 4000rpm and it pulls harder than a stock RB26 at 15psi at 4000rpm (and then it gets much, much worse for the stocker beyond that).
                        My definition,"LAG is the time the guy beside you thought he won"
                        Cam Koole
                        Technical Services Consultant
                        Lightspeed Innovations
                        Red Deer, Alberta
                        1-866-95-84732
                        cam@lightspeedinnovations.com
                        www.Lightspeedinnovations.com
                        North American EMtron Distribution
                        Whiteline Canadian Distribution Center
                        EMtron Training Center Coming Soon
                        2WD Mustang MD250
                        Dynapack 4000 AWD
                        Distributer for
                        Exedy, JE,Carrillo, CP Pistons,
                        K1 Technology, This is a very
                        long list and if you actually read it'
                        cool. Just call we can get it LOL
                        2WD Mustang MD250
                          they sound like 2860rs turbos
                            yes the are.
                              Amazing definition!
