Just put in garret 2860-5 turbos . have a problem.
It's possible you bought the wrong turbos. the GTS using a different exhaust housing than the compact 5 bolt used on a GTR. It's been known that people buy the cheaper turbos but get stuck with the wrong housings... the only mod I needed to do was the oil return and oil feed reducer.
turbine A/R should be .64 however there is an option for larger A/R.
I love lag, it's the calm before the storm. I wouldn't want it any other way, you can cruise around under 4000rpm and get 25mpg (which I do), then beat the living tar out of a ZR1 when you get up on the meaty part of the boost. I make 3-4 lbs at 4000rpm and it pulls harder than a stock RB26 at 15psi at 4000rpm (and then it gets much, much worse for the stocker beyond that).
North American EMtron Distribution
Whiteline Canadian Distribution Center
EMtron Training Center Coming Soon
2WD Mustang MD250
Dynapack 4000 AWD
Distributer for
Exedy, JE,Carrillo, CP Pistons,
K1 Technology, This is a very
long list and if you actually read it'
cool. Just call we can get it LOL
2WD Mustang MD250
