Hey , i am starting my motor built ( rb26 ) i was just curious wich way i should go twin turbo or just big single turbo .... my goal is 600-700+ whp ( lets hope
) i will be happy with 600 whp , i was thinking to use twin gt2871r to archive my goal , i am tryng to stay away from lag the big turbo's have !
sugestion to the block built ? , i have now a n1 block oversized at 87 mm , what pistons u suggest , oil pump , water pump , rods and bearings , sleeves needed ??any other suggestions ?
for the head its getting port and polish , 3 angle valve job , bronze guides int/ext , port match to intake manifold ( single throttle 90 mm ) , exhaust port match to twin hks manifolds , planing on some new cams 272 , including new springs , any other suggestions ?
i know there is injectors , fuel pump , stand alone req , but i just want the mecanical part to be strong to support my idea !
) i will be happy with 600 whp , i was thinking to use twin gt2871r to archive my goal , i am tryng to stay away from lag the big turbo's have ! sugestion to the block built ? , i have now a n1 block oversized at 87 mm , what pistons u suggest , oil pump , water pump , rods and bearings , sleeves needed ??any other suggestions ?
