I wanna stay twin turbo if possible , already purchase hks manifolds with turbo elbows , i would like to run twin gt2871r ... It should hit the 600 whp pretty easy with the rest done up to the engine thats what my tunner said .. Will see now looking for pistons and rods to suport the power ? Any sugestions ?
r32 gtr --> twin turbo or single turbo and mods to block ?
I've certainly enjoyed my -5s, lots of fun.. But this year I'm going for about 550whp with a bw 7670 efr. It looks like it will spool as fast as the -5s without the compressor stall etc.. Btw Marius, make sure you do some reading about compressor stall and turbo shuffle so you know how to tune the car with those big twins..Originally posted by Super_Dude View PostTwin 2871's are laggy as hell on anything but a RB30. Your much better off checking out the new borg warner efr's if you want response and more than 600whp.But if you want to run twins I would avoid -10's. -5's have proven themselves to support 550+whp and are responsive.
I thought of that and realized I liked things better without one :S I don't want people to judge what choices I made. I'll post pics at some point.Originally posted by amnash View Post70K!!! damn lol have a build thread?No build thread.
1991 nissan
El terror
If you could post before and after results it would be greatly appreciated.Originally posted by DougTaylor View PostI've certainly enjoyed my -5s, lots of fun.. But this year I'm going for about 550whp with a bw 7670 efr. It looks like it will spool as fast as the -5s without the compressor stall etc.. Btw Marius, make sure you do some reading about compressor stall and turbo shuffle so you know how to tune the car with those big twins..oh hai!
Sure, you're thinking about the same thing? Feel free to email me if I forget, I'll PM you my email..Originally posted by Black BNR32 View PostIf you could post before and after results it would be greatly appreciated.
Before is here: http://photoshare.shaw.ca/image/c/2/...dyno-0.jpg?r=tLast edited by DougTaylor; 04-27-2011, 11:24 PM.
I had twin gt2860-5 and this year I'm switching to a single. The twins actually have some lag, there's a big issue with high boost causing turbo shuffle. A proper single will make more power then a twin setup and have the same or less lag. The single is more efficient, there's less chance for the air to become turbulent.
That's more an opinion than fact. There are many threads and forums out there that disagree.Originally posted by mitch32 View PostI had twin gt2860-5 and this year I'm switching to a single. The twins actually have some lag, there's a big issue with high boost causing turbo shuffle. A proper single will make more power then a twin setup and have the same or less lag. The single is more efficient, there's less chance for the air to become turbulent.No build thread.
1991 nissan
El terror
Imo you Don't need Carrillo rods or valves. If your oem valves are good they're fine to 800hp, safely. As for rods, there's no need for 1000hp+ rods when rods that are less than 1/2 the prices are good for 800hp like eagle, manly, spool (just to name a few) why build for 1000hp when you will safely run on 700-800hp parts with much less cost. No need to over I'll unless you have a good budget to go with. I went crazy cause my vehicles are paid offOriginally posted by marius850r View Postany particular models ?
Andy total bills with mortage still leaves me a good lump of cash at the end of te month. If you're building for 500hp but dont really have the large amount of cash, a built engine doesn't need to cost 20k.
Cp pistons (oem size so you had max cylinder wall strength), eagle rods, tomei gaskets, drop in cams Kirk greddy or tomei, n1 oil pump, oem water pump, 044 fuel pump, 720cc injectors and your good for 500whp. Less than $15k I'm sure, with machine shop labour. It wont be expensive Unless your engine is wrecked and you need parts. Most of us use these parts and they're fine. Eagle rods are some $600 and carrillo are $1000+. If you won't see a $50k+ build, the carillos are overkill. ReallyNo build thread.
1991 nissan
El terror
. They spool wick fast and should be able to support 550-600 with a built motor and good cams
