BOV questions!!!
  • BOV questions!!!
    Hey guys I'm looking into buying a new BOV for my gtr. I just had a couple of questions for anyone that can help. Whats a good choice for BOV's, i was looking at the blitz style. Do I need 2 of them like i've seen on other rides or will one work. Is there any complications with installing them...as in will i need to remap or is it pretty simple.
    and i just found out my fuel injectors are leaking... whats a good brand to choose, I'm just running stock boost with just intake pods and an exhaust
      for the bov, you can install 2 and use the oem piping. You can use 1 as well with no issues but you'll have to weld a flange on your piping or like i did: i bought a greddy type R bov with the recirculate kit. So no soldering needed! The type R is for high boost applications tho.... HKS, synapse, BLITZ, turbosmart and tial have also good stuff to choose from. Check on youtube for the different sound they make, so you can choose... Some members here will say that they don't run any bov: I don't feel comfortable with that idea...
      Injectors: if you can find another set of good condition, stock injectors. Or if you can spend a lil, injector dynamics, HKS, RC... Make a lil search on the web, so you can compare prices... But yeah, with aftermarket/bigger injectors, you'll have tu get the car tuned... As well if you swap you recirculate bov for vented style
        Stock injectors are said to be 440cc, but someone on here said 480cc when flow tested. Second hand GTR injectors from a low km R34GTR or similar might be your only option, as most injectors sold are bigger with cc than stock injectors.
        Synapse BOV and they sell a BOV kit for GTR -
        They can run in push configuration (like stock BOV, where boost pressure can push them open, which is a form of overboost protection) or pull configuration (boost pressure keeps valve closed). They will make engine run slightly leaner (where the extra hp comes from).
          thanks guys thats great help!!!
            try looking for a hks ssqv4 they sound nicee
              I think my one injector is leaking to. Can I get bigger ones, then drive to get it tuned? I plan on having it tuned next spring but might as well get some big injectors before! I'd adventually like to hit 500hp, what's a good size?
              Thx, sorry to jack ur thread
                You need to adjust injector settings, which adjust's fuel map, as it will run too rich if you don't.
                For example of what happens when you don't adjust for bigger injectors -
                I would rent a drive on racecar trailer and get someone to tow it. Or put on a flat bed towtruck.
                Also need higher lph fuelpump to match injectors, fuelpump hardwire kit.
                Use calculator to work out size of injectors for hp level (engine) you want -
                  Target Crank HP kW PS # of Injectors Induction Type Turbocharged Supercharged Naturally Aspirated Fuel Type Gasoline Ethanol Methanol Ethanol Blend E98 E85 B.S.F.C. Value (optional) Max Duty Cycle (%) Injector Flow Needed 0.00 cc/min Reset Target Crank HP Induction Type Naturally Aspirated Turbocharged Supercharged F
                Use 80% duty instead of 90% and a fuelpump manufacturer recommended 0.75 B.S.F.C for turbo engine, but they suggest .5 or .6.
                Fuelpumps have flow data to say what rough hp they will support. Up to 80psi is the area you look at on chart -
                Upgrade with DeatschWerks' high-performance fuel injectors, pumps, regulators, lines and fittings. Engineered for 400–2200 HP, built for racers and tuners worldwide.
                  From what I understand and feel free to correct me if I'm wrong but the gtr uses a recirculating bov and if you change It without a tune the car runs rich in between shifts? I may have miss understood that but someone feel free to chime in
                    GTS x1 BOV, GTR x2 BOV's run recirculated BOV's.
                    If run a atmospheric vented BOV, engine can run rich between gearchanges due to running a draw through MAF that can't adjust to loss of air inside intake piping behind MAF. If run recirculated BOV it sends vented air from BOV back into intake piping behind MAF and through turbo, so there's no loss of air inside intake piping.
                      are there any risks associated with running rich if I were to swap out the recirculated for atmospheric?
                        Depends on how rich engine runs / how BOV is set, etc.
                        If engine runs rich enough, could wash oil off bores of cylinders and get into oil in sump, thus spoiling the oil, which could cause excessive wear problems. Get popping, flames from exhaust. Foul sparkplugs (if wrong heatrange). Turbo slows down too much when back off throttle and get reversion (air reversing direction, then back into MAF's causing them to make ECU make engine run rich and stall). Also that results in slow transient response (time it takes from pressing throttle to engine pushing you back in seat) if it doesn't stall, as turbo, etc has to get back up to speed.
                        If want to run atmosphere BOV, fit a aftermarket ECU with MAP sensor (MAP sensor is connected to intake manifold), so ECU can compensate for loss of air inside intake piping.
                          thanks for the info. I got a list of things to do before I start to mod the car in any way
