Quick question
  • Quick question
    I want to polish my valve covers over the winter. Will I need to replace the valve cover seals? If so where can i get them?
    Sent from Mars.
    DRIVE FOR THE LOVE
    1995 NISSAN SKYLINE GT-R R33 V-SPEC GOHAN
    replacing them is never a bad idea along with the half moon seals. However, you only need to replace them if they are torn or worn visibly or leaking. you can get the kit from any nissan dealership or ebay or any sponsor.
      You think nissan would be able to get them?
      Sent from Mars.
      DRIVE FOR THE LOVE
        I know they can. the half moon seals are the same as a z32 but the valve cover seals are different.
        Nissan OEM Genuine RB20 RB25 RB26 Valve Cover Gasket.  Replace your old one with a Nissan one!Intake and Exhaust Kit.Vehicle Fitments: Year Make Model Submodel 1991 - 1998 Nissan 240SX LE 1989 - 1998 Nissan 240SX SE, Base 1989 - 1990 Nissan 240SX XE
          i got my valve cover gasket kit with the half moons from right drive for about 80 shipped. worth it imo
            Also don't forget to have a look at the 20 bolt washers for the valve cover. They are washers with washers stuck onto them. They are quite pricey but I found out most of mine were so worn out and aged that it looked like donuts
            I replaced all 20.
              those are the crushable washers. they are supposed to be squeezed down. unless they are ripped and torn apart they should be fine.
                So the verdict is that you can reuse the gasket, washers and half moon things? Unless they're torn or badly warn?
                I'd like to do the same to my rb25
                Also, has anyone ever tried to polish up the intake pipes that run across the cam covers? And or the intake manifold itself?
                They're more textured.. I it possible to polish these up/sand them down so they look like the newly polished cam covers?
                -not trying to jack the thread, just askin
                01 Chevrolet Maliboom-boom (winter BEATER)
                93, 94, 96 Toyota Supras
                95 R33 GTS-T
                04 R44 Raven1 helicopter
                  If don't change the washers it leaks.
                  Permaseal sells a kit with halfmoons, gaskets, washers (I think better than factory washers, as I noticed the washers fits inbetween the screws, camcovermount hole to stop camcover moving around, but are easy to break when edge of washer hits camcover when turning screw, but can shave edge of washer a bit to clear camcover without breaking), oil filter cap gasket.
                    You should always replace the valve cover gaskets and half moon seals, or they will likely leak. Considering they are cheap, it's worth replacing now to save a lot of extra work later.
                    We always have lots of stock of these pieces, PM me if needed!
                    RightDrive Inc. Parts Manager
                      they dont always leak. i didnt replace mine and i have absolutely no leaks. i am with daryl for sure about changing the gaskets but unless the washers are in really bad shape then they are fine. i reused all 20 of mine and no problems. hell i ran without one for a week till i got a new one since i lost one and i had no leak there.
                        It leaked on my car.
