little help if possible
spec, forged r32 gtr, nismo afms, stock ignition, bkr7e (0.8mm), powerFC, nismo fuel pump (wired off battery), sard 700s, about the only important things werth mentioning.
symptoms;
missing at idle
after car is warm, if i sit at idle, i notice on my commander unit that the battery voltage drops slightly, starting at 13.7v, and drops gradually by like 0.3vs and i notice my afrs getting leaner and leaner. quick rev brings voltage up and in turn afrs. but back to idle again is very lean, 16s, 17s then off the chart.
when i put my headlights on, commander shows very low 12.9-13.0v and my afrs go mental lean and it stalls
before this i had been driving the car fine, boosting well, soon as i parked up, putting car in the garage, this happened.
any ideas??
only things ive checked is battery, which is 11.8v non running, but when car started shows 14.2v. (so alt ok? ) commander generally shows about 0.7v less than what the battery is seeing.
definatly feels to me like the fuel pump is loosing power (gradually got less loud, especially when i put my headlights on), this im guessing ment less power to fuel pump (tho ive yet to check voltage at pump), and in turn less fuel pressure? causing leaning out and stalling??
initally i was looking to find out why the car died when i put the headlights on, now i know its because im loosing 0.5v instantly at the commander and it must be dropping the fueling???
had no missing before and during the drive!
on cold start its fine, im guessing because revs are 1200-1400rpm at this point and giving the car plenty of voltage.
should the pfc be seeing more than 13.3-13.5ish volts at warm idle??
it seems odd to me to be reading a good 0.7v less than when measuring voltage at the battery with a multimeter?
where to start given the info above???
thanks
symptoms;
missing at idle
any ideas??
thanks
