That's the odd thing, headlights on dropped the reading at the battery by only 0.1v, however powerFC sees a drop of 0.5v. Which it clearly doesn't like too much.
It may just be the powerFC needs to idle relearn again? perhaps that wasn't accounted for at mapping time when all the electronics are on. I did note the a/c dropped it a further 0.1v at battery which gave me a total of 14.1v at battery (14.3v with no a/c, no main beam), 12.9/13v at the powerFC (with main beam)
Soon as main beam switched off powerFC sees 13.5v again.
Just don't know if these 2 issues are related. As I don't need main beams on to see the leaning out at idle.
The leaning out at hot idle is rather annoying and I understandably want it sorted. I just can't work out if it's part or map related.
I'm going to swap in my oem injectors/afm and ecu and see what happens.
That will at least let rule in or rule out those items.
Any possibility it's something else? Doing my head in.
