currently i am running power fc with twin gt 2860r turbos. i am about to do a single swap to a pte 6266 and wanted to get an idea of what the best solution is for the twin maf.
the options that are being considered is building a suction pipe for the twins, going single z32, or go ford lightning maf.
the power goal is going to be 600ish at the wheels. any help would be greatly appreciated.
in case it matters this is the current set up more or less
+Wiseco .20+ bore pistons with skirt coating
+Manley H-beam rods
+ACL race bearings
+ARP head studs and main studs
+Cometic head gasket
+Supertech valve guides and valve seals
+Tomei Outlet pipe
+Custom 3'' downpipe and test pipe
+Greddy SP 3'' exhaust
+Mishimoto radiator
+Flexalite dual 12'' fan kit
+Greddy Catch can
+Greddy Intercooler with custom 3'' piping
+Custom Fuel rail with Fragola fitting and black braided lines
+Fuelab Regultor and fuel filter
+Deatschwerks 300lph pump and Walbro 255lph pump
+Deatchewerks 750cc injectors
+AEM Meth kit
i will be using a DOC racing manifold, tial 44mm wg, and 1000cc injectors
again i need some help on the maf options
thanks
+Manley H-beam rods
+ACL race bearings
+Tomei Outlet pipe
+Mishimoto radiator
+Greddy Catch can
+AEM Meth kit
thanks
