RB26 Rebuild
Not sure on the fuel rail, but the intercooler sure can.
And if you're planning on making "550+" you need a front LSD, a rear LSD is a damned good idea, and you're probably going to be needing to upgrade the internals in your gearbox. Lots of UK guys breaking 3rd gear at 500-550 WHP.1990 Skyline GT-R - Jet Silver Metallic
It'll run someday
Alright well i will probably order the hks fmic then but im not sure about the fuel rail either...
Anyone in the lower mainland get there gearbox upgraded just curious about parts price and such...
Now onto LSD front and rear selection who is using which brand and whats best and what works...
throw me some more info and ill look into getting some new driveline parts for the build as well, cant be throwing down 500hp+ if the drivetrain cant support it!!!
The main input shaft flexes causing the gears to not engauge 100% and stripping the teeth, since 3rd is in the middle. It flexes the most, hence most prone to strippage.Originally posted by curtisgoodman View PostAlright well i will probably order the hks fmic then but im not sure about the fuel rail either...
OSG makes a drag 123 gear set as well as a strengthened input shaft. Maybe that would be your best bet? Don't really hear much about diffs breaking from what I know?
I would upgrade your tranny before you do LSD's, 3rd gear is the weak point for sure. I'd say upgradding your front and rear diffs to LSD's would increase your chances of dropping out 3rd.Originally posted by curtisgoodman View PostThats a good idea but what else am i missing to make the build more reliable... im looking into an oil cooler and some LSD's for the front and rear of the car but what else could i add to my build?
Thanks
alright so the OSG gears are stronger thats good but is the 123 drag ment for the strip or what... this is going to be a street daily driver i dont want anything ment for the strip or track just stronger then stock... could i get a new stock set of gears and treat them or am i better off getting a whole new setup... anyother choices besides the OSG set id like to read up on a couple other types as well.
thanks
Just have the tranny rebuilt with new bearings and gaskets.. Way cheaper and it got rid of my 4th geear grind as well. I think its like 700 including labour and parts and stuff. Also look at a fuel surge tank. Trevor is getting me some extra fuel items so maybe a group buy is in order? Make sure all your boost pipes are hard pipes now as well. That costs some $$$. A good A/F gauge is in order and aybe even a knock amp gauge would do you good.
