Your IC piping blew off probably because of either or both of the following: lots of blowby and oil in the system which made the connection get slippery, and/or higher temperature which caused slightly increased boost/boost-creep. Turbo cars running more then stock boost typically blow couplers when the couplers arent upgraded. If you want to ensure your stuff doesn't pop get vanjen clamps, t-bolts, or make a turbo coupler brace. Vanjen clamps are amazing just too expensive for a street/weekend track car.
the coupler popped off because, i think, last year i used a tiny bit of grease on some of the couplers, grease doesn't dry nor move around, and the t-bolt clamp probly wasn't tightened enough
the clamp didn't come loose, its just the coupler slipped off,
anyways, its fixed and very solidLast edited by frankiman; 08-24-2011, 01:34 PM.
I can't remember where I saw this or who told me this, but before putting couplers it's a good idea to use
spray net on the pipes, yes the stuff girls puts in their hair. It's slippery when it's wet, and get's really sticky
when it dry.14 VW Jetta TDI
95 240sx (RB25DET powered)
95 240sx ( powered)
89 GTR - Money Pit -
Originally posted by collector240sx View PostI can't remember where I saw this or who told me this, but before putting couplers it's a good idea to use
when it dry.
The spray net was suggested for holding bmx grips on the bars, tried it and ended up with grips in my hand and a mouth full of dirt, lol. Heat and humidity will turn it into grease.Originally posted by SnowSure a condom holds water but you don't see me drinking from one.
when it dry.1992 BNR32 SKYLINE GTR
what did you change since the last dyno?Need detailing done to your car? I'm open to travel to detail your car :
