My New R33 GTR - so it begins...
  • PurpleStreak
    replied
    Originally posted by ColinR33 View Post
    More parts arrived today!
    Tein Mono Flex Coiovers, Nutsuren wrenches, Mines baffles.
    Just one or two more shipments and ready to go!
    waaanttt
  • ColinR33
    replied
  • r33_gtst
    replied
    Originally posted by cortexx View Post
    It's going to be a long cold winter
    And a fun, boost filled summer!
    I hope you don't like what you see when you remove the head. N1 built bottom end FTW!
  • ColinR33
    replied
    Wow. Me gusta. Me jelly, too.
  • cortexx
    replied
    remove head and clean up valves , new poncams , new HKS valve springs , titanium retainers , 8mm stainless cosworth head gasket ARP head studs , Nismo intake , 680cc hks injectors , HKS dual feed fuel rail , Tomei fuel pump , Sard FPR , russel lines and fuel fittings , Apexi power fc install , powdercoat my valve covers to something not shiney. replace the N1 water pump , tomei timing belt , all new timing belt idler pulleys , single large electrich fan for rad .
    If i dont like what i see when i remove the head ... n1 block, cosworth pistons, new rods and crank with a tomei oil pump all fully balanced with the existing nismo flywheel and clutch assembly, oil pan baffle , oil restrictors in the head....
  • ColinR33
    replied
    Thanks Paul, more to come, doing mostly reliability/monitoring and suspension mods this winter. Hoping to go to a white face cluster with 320 kmh speedo too soon, but sadly not in the budget for this year. Got the white face Defi's too. I'll try the trick with the H cut, seems like the way to go. What have you got planned?
  • cortexx
    replied
    Hey colin , nice pile'o'parts - im in the process of parts accumulation myself Youhave the same gauges as i had last winter to install I chose the white face ones because eventually i want the 320klmh nismo cluster , the standard cluster wraps the speedo needle too fast now
    I cut the H pattern into my dash with an xacto knife and then drilled through the hard undershell with a 1/2 inch drill , if you remove the pod the H pattern can easily hide the hole as you not removing any material.
  • ColinR33
    replied
    Originally posted by GTRADDICT View Post
    There is a thread/trick here to cut in the vinyl and not leave a mark if ever you want to remove your gauge. Cut a "H" hole and push in the flaps. Pop them back up if you remove the gauge.
    I'll have to check that out, thanks for the tip.
    Originally posted by PurpleStreak View Post
    Colin you used to get hesitation after 5k rpms? Mine just started doing this yesterday
    Yeah, up around 6-7k she'd start to miss a bit. Took my coils out, cleaned them and taped up one spot and that seemed to help, but the Splitfires do make a noticeable difference.
  • PurpleStreak
    replied
  • GTRADDICT
    replied
  • ColinR33
    replied
    I know, but unless I can come up with a better idea, could run them thru the vent, but will still see them, ditto if thru the defrost vent.
  • cschepp
    replied
    Face palm, really man? That would be a shame
  • ColinR33
    replied
    As much as I shudder at the thought, I will probably drill a hole to run the wires up directly under the pod and keep them hidden, going to try to keep it clean as possible.
  • cschepp
    replied
    After seeing that essential gauge pod in cortexx's car man does that thing ever sit nice. That's going to look excellent! How do you plan on hiding the wires though?
  • ColinR33
    replied
    Well, the pron content of this thread has been seriously lacking for the last little while as I have been far too busy enjoying the car, but now I am starting to accumulate parts for my winter build:
    Defi link & gauges, gauge pod, Splitfires and new coilpack harness arrived today courtesy of Adam @ Feast. Like a little kid I couldn't wait and ran out to install the Splitfires and take it for a rip. Much smoother response, feels a bit peppier, no more high rpm stumble.
    Innovate MTX-L wideband
    Greddy oil cooler to go along with my relocation kit (needs a good cleaning
    More goodies to come!
