Markdett's r32 GTR restoration and full engine rebuild.
Did a few comparison photos of Nismo VS standard rb26 plenum.....
A little more balanced across the numbers (note the restriction to number 6 inlet on standard plenum).
Collector size is a fair bit larger then standard
Nismo
Standard
Note how harsh the castings are on the standard one.
Nismo
Standard.
Engine is now assembled as a long motor, and started bolting everything around it this week.
Heres a photo abit of the way through the assembly of the short motor.
And heres another one im putting into a territory ATM. (slightly unrelated but good on the eyes)
Had a set back with the crank shaft though. For some strange reason one of the centre bearing thrust faces had not been cleaned/linished. Why? your guess is as good as mine. Also noticed a slight groove on the surface also. Took to the machinsist's and got them to get the surface smooth again and a linish. Think he said he took about 2thou off it. Re-checked crankshaft end float and thankfully we were still well within the manufacturers specs.
I now also have a spare dash which im going to get flocked with a few other interior trims. So stay tuned for some pics, will also upload more of the engine getting put together in the next few days!
Short motor is now assembled. Needs to purchase manifolds and its ready to put in the hole.....
Here are some pics.
2 degrees advanced on the inlet, 2 degrees retarded on the exhaust. ATI 1000hp dampner
Exhaust ports (again)
Inlets (again)
Wrinkle red, looking kind of orange :\
tada!
Large package arrived for me today from Tomei, Lets upon it up and see whats inside.....
Box 1
Tomei expreme turbo outlet's. I believe expreme refers to "supreme exhuast"
quality casting
Inlet, unseperated.
Outlets which i believe are 2.5 inch.
Box two is a Tomei fuel pump. Kit is direct fitment, even comes with OEM tank seal.
Box three is Tomei expreme exhaust manifolds
I believe this are the 2nd type (after the had problems with others cracking). Welds inside the manifolds for reinforcement, and thicker metal?
Quality of welds is 2nd to none.
Larger diameter manifolds outlets, which have come ported.
Larger diameter and ported inlets too.
Here are some pics.
Inlets (again)
tada!
Box 1
quality casting
Inlet, unseperated.
Awesome products by Tomei!
Mocked up the turbos. Decided to run the Tomei multi layer exhaust manifold gasket rather the the HKS one (supplied with the HKS head gasket kit). The Tomei gasket has a much thicker center layer over the HKS one.
Had to carry out the usual mods to the oil drains (enlarging the holes).
Received a large package from RHD the other day (took 3 days to get from Japan to my doorstep). This was its contents.......
The wallet hurter!
Mines Cam baffles
Started on the Intake side today.
HKS metal gasket Hylomar'd and ready to roll!
Last look at the port before i close her up
Bolted up/Torqued
Smooth out the DJ nipples
Started the fitment of the Mines triple flow cam baffles. Kept hearing stories of how people had to modify to get them to fit. I didn't run into ANY clearance issues when fitting these. Im also running Tomei cam studs which stick out alot further then stock.
Original Baffles
Baffle plate removed (notice the OEM gauze)
Gauze (one from each cover)
New gauze supplied with cam baffles fitted
Baffle plate installed
Here's a pick of how much larger my cam studs are. Also had to remove the oil splash guides and fit them to the last two cam caps
Shoulda bought a Tomei long block lol. They send it assembled (one of the top 5 RB shops in the world IMO)
They're not that expensive, the cheapest long block they have is $17k!
nice project car though probably one of the best in Canada!
Edit: haha, you're not in Canada, nm... you Aussies are wild!!! thumbs up!
The cam baffles, I dont' know how you didnt' have clearance issues, I used the same exact parts and had to chop down 4 tomei studs that were hitting the baffles. As for the foam, now I know what that was for lmao, I couldn't read japanese so I assumed it was packaging crap which I chucked! I would have clued in had my stock covers had the gauze though they didn't...
