So its pretty ugly out and the Miss' is out with friends, figured I'd start a build thread.
So after having some tough luck with my Rx7 Fd (fire loss... effin rotary) I decided to find myself another R32, #5 to be exact. After searching and searching, checking auctions, looking at cars from vancouver to halifax I was undecided on what to go with and wanted something already built, something I could just turn the key and enjoy, have lots of time for other stuff and not worry about having a project. Obviously my good friends at modworks wouldn't let that stand and they convinced me to buy a project.
So I've picked up a 1992 R32 GT-R. After looking for a while and debating between a few in montreal/toronto i decided to go with a oddly coloured blue one. (came with the following goodies)
Garret GT2860R -5's
Haltec Platinum Pro
Denso 285L pump
Sumens 780cc injectors
3 Bar Map sensor
Tomei Expreme exhaust manifolds
Mishimoto Rad
Aem Wideband
Apexi Exhaust with custom Ypipe from Rawtec montreal
apexi intakes
HKS turbo timer
Spec stage 2+ clutch
project M brake pads
cusco adjustable pillow ball tension rods
and a full sound system (not like thats important)
Pulled the trigger and loaded it on the trailer for the trip back to New Brunswick. The original plan with this car was to pull the motor, mild tuck, redo engine bay keep the twins and do an overall refresh on the motor. Body wise on the other hand was a complete restoration, this car has practically 0 rust, slight surface rust around back glass where it was not sealed correctly will be an easy sand blast fix.
After pulling it off the trailer a few ugly things were discovered, 3rd to 4th grinds awfully so a new tranny is in need, and the u joint is toast. all said and done this is a great starting project for an unreal car
so now onto the build plans.
Completion Date Goal : September 25th 2015.
Body:
Complete restoration, every rubber, window seal, exterior piece will be replaced or refinished to a factory state with a show quality paint job.
Engine:
Full build, will update as the parts come in. this has turned into enough of a novel haha. pics to come soon!
Garret GT2860R -5's
Haltec Platinum Pro
Denso 285L pump
3 Bar Map sensor
Mishimoto Rad
Aem Wideband
apexi intakes
HKS turbo timer
so now onto the build plans.Completion Date Goal : September 25th 2015.
Body:
Engine:
