r32 gtr rad
  • r32 gtr rad
    im looking to replace my rad soon. any recommendations? koyo? mishimoto? i want to be able to fit the oem fan shroud and retain the engine driven clutch fan. i see koyo has 2 sizes 48mm and 50 something mm. which ones did you guys use?
    I recently with the KOYO, P#: HH020214, which I think is the 48mm one, haven't measured it but from what I know, it retains the stock shroud/fan setup.
    (ノಠ益ಠ)ノ 1990 BNR32
      I went with Mishi just due to availability and cost. Well built with lifetime warranty. The rad cap sucks, but I had a Nismo anyway. Would recommend.
        louis110 were you able to fit this mishimoto unit with the oem rad fan shroud?
          ck_chino Yes, still using the oem shroud with no modification needed. Screws up at the top only though, but no effect on the way it's mounted.
