hey gtrc
finally had a few hours to work on the car again and its close to being out now.
i have to build my hoist tommarow and then i can start work again.
my question regards the tranny bolts. i havent gotten a clear explanation yet but when getting the upper bellhousing bolts off, i can lift the motor a few inches and then bring it forward. then i would rest it on the front crossmember and that will enable me room to get at the bolts from up top on the hood side?
with the tranny and rear driveshaft still connected will then be able to move forward a few inches?
and for the starter and wiring harness thats located under the plenum, i cant seem to get at them. i have a good view from under the car with the fron prop shaft out of the way but not enough room to get my hand sin there to start removing things.
can i get at these after bringing the motor up a bit so that the plenum sits a bit higher then the strut tower top so that i can get at these parts? or will that not work?
thanks guys for your patience and answers - gtrc truly is the best forum ive been a part of! :bow down:
