is it a factory deck? If not check to make sure that it is using a separate ground on the harness and not into the factory "earth". Same thing for the turbo timer. Though typically if the wiring is the issue regarding the grounds the dash lights go too.
Translated Fuse Box Diagram?
This is a sticky topic.
It is a factory deck. My dash lights still work, the turbo timer works. I looked at where the turbo timer wire leads to and all I could see was that it goes up to around the clock area. My stereo harness looks like it hasn't been messed with. I could be wrong though as I don't know much about wiring1992 Skyline GTR - Garage Queen
2009 Dodge Caravan - Woopee
1989 240sx - Rusty Beater
1979 Nomad Skyline - 23' Camper Trailer
I wonder if my problem is a fuse... My unit inside the car (fan/heat/ac control unit) isn't working. It was one I first got the car it was working. the dealer i bought it from put in a new rb26dett for me. but NOW the Fan/Heat/ac unit isn't working. now that it's october its cold and i need my heater. I'm missing a fuse under the hood in the Main doc (75 A Main) is missing... is it this or am i totally out to lunch. If any one knows anything that could help that would be great!
Quick question.
in the fuse box under the dash, I have 3 vertical fuses missing. tried to put some in and there was no contacts in there, so i believe they are not needed. And the 4 horizontal slots on the bottom of the panel, what are they for? Thanks
Just a guess here, did you check the first page? Sounds like fuses:Originally posted by cbileske View PostQuick question.
24 Spare
25 Spare
26 Spare
27 Spare
28 Diagnostic coupler
29 IGN relay
30 ACC relay
My guess is 27 through 30 are the horizontal ones on the pic1992 BNR32 SKYLINE GTR
I am having a problem with the fuse for my headlights/tailights/and dash lights. The problem is the fuse keeps blowing as soon as you turn the lights on. I have checked the wires and all seems good. Is there a relay for these lights ? If so where is it located ?
I have a 95 GT-R33
There are a bunch of fuses in my trunk as well as a few replays
please help
