Block: 05U supposedly early block (no serial)
Rods: Eagle
Rod Bolts: ARP 2000
Pistons: CP
Pins: CP
Guides: Tomei IN/EX
Springs: Tomei type B
Cams: Tomei type B
Cam cap bolts/studs: Tomei studs
Crank: New R34
Main Bearings: Nismo RRR
Rod Bearings: Nismo RRR
Head gasket: Tomei
Oil Pump: Tomei
Cam cover Baffles: Triple flow
Oil pan: Oversized
Other oil mods: Accusump, twin -8AN head oil drain
Oil capacity without accusump: 9L
Water Pump: N1
Timing Belt: Tomei
Cradle/Main Fasteners: ARP studs
Harmonic Balancer: ATI 1000hp
Special Build Notes:
Machine Shop: Don't know
Shortblock Assembly By: Monkeynuts
Porting: Custom intake/exhaust, manifolds, outlets, turbos
Crank Prep: Don't know, no paperwork received
Rod Prep: Don't know, no paperwork received
Balanced Rotating Assembly?: Yes
Block Prep: 1mm overbore, Honed, don't know the rest
Torque Plate Used ?: don't know
Special Modifications to Parts: Don't know, no paperwork received
300km on new engine. HARD break-in since startup, low boost (1bar, rpm limit at 6k till break-in is done).
Rods: Eagle
Rod Bolts: ARP 2000
Pistons: CP
Pins: CP
Guides: Tomei IN/EX
Cams: Tomei type B
Crank: New R34
Head gasket: Tomei
Oil Pump: Tomei
Oil pan: Oversized
Water Pump: N1
Timing Belt: Tomei
amn skippy
