Well, similar to the MOD Database, let's do one better and share the wealth of knowledge and more importantly, FIRST HAND EXPERIENCE.
I find it extremely difficult to believe that there are so many engines being built in Canada, yet there is almost NO information on them that people are willing to share DIRECTLY in terms of their individual experiences. This is a cause for not only confusion, but frustration by some considering the banter on the Internet in regards to BAD PARTS, BAD SHOPS etc. Let's hear it from the 'Horses Mouth' so to speak.
I simply want to get to the bottom of most of the CRAP.
It seems that someone ALWAYS has a friend of a friend that has killed an N1 Oil Pump - BUT NEVER THEMSELVES.
It also seems that someone has also been told of Eagle Rods failing - but never experienced it themselves.
Let's set the record straight and put the Internet Pollution to bed once and for all.
THIS IS NOT FOR JDM BUILT MOTORS - JUST CANADIAN & AMERICAN...as in, NOT BUILT in Japan.
So........
COPY>-----------------------------------------------------------------
RB26 Engine Shortblock Build Database:
Block:
Rods:
Rod Bolts:
Pistons:
Pins:
Crank:
Main Bearings:
Rod Bearings:
Oil Pump:
Water Pump:
Timing Belt:
Cradle/Main Fasteners:
Harmonic Balancer:
Special Build Notes:
Machine Shop:
Shortblock Assembly By:
Crank Prep:
Rod Prep:
Balanced Rotating Assembly?:
Block Prep:
Torque Plate Used ?:
Special Modifications to Parts:
Any other points to add:
Post Build Notes:
Specific Part Failures:
Overall Shop Experience:
-----------------------------------------------------------------<PASTE
I will use my imaginary friend 'Allan' as a starting Point to show as an example of using the above template.
Block: Early R32 Rb26
Rods: Eagle H-Beam Forged
Rod Bolts: ARP 2000
Pistons: CP 87mm Forged
Pins: CP
Crank: Brand New R34 Nissan OEM RB26
Main Bearings: ACl Race Series, STD
Rod Bearings: ACl Race Series, STD
Oil Pump: Nissan N1
Water Pump: Nissan N1
Timing Belt: Greddy
Cradle/Main Fasteners: OEM Nissan RB26 Bolts
Harmonic Balancer: ATI 500HP, #918599
Machine Shop: Bob's Machine Shop, Imagination Land City, Alberta
Shortblock Assembly By: Bob's Machine Shop
Crank Prep: Polish only, as it was new (no collar required, no turning)
Rod Prep: Bearing Clearencing Only
Balanced Rotating Assembly?: YES
Block Prep: +1mm over bore, tank, magnaflux, line hone, Oil gallery mods, Tomei Oil restrictor.
Torque Plate Used ?: YES
Special Modifications to Parts: Bearing Clearencing/Blueprinting only, None otherwise, all bolt in
Any other points to add: My Friend's, Sister's, Husband's, Boss's, daughter told her neighbour that people kill N1 Oil Pumps because they are too cheap to buy a balancer.
Post Build Notes:
Specific Part Failures: None
Overall Shop Experience: Good
So........
Block:
Rods:
Rod Bolts:
Pistons:
Pins:
Crank:
Main Bearings:
Rod Bearings:
Oil Pump:
Water Pump:
Timing Belt:
Harmonic Balancer:
Machine Shop:
Crank Prep:
Rod Prep:
Block Prep:
Post Build Notes:
Rod Bolts: ARP 2000
Pins: CP
Oil Pump: Nissan N1
Timing Belt: Greddy
Post Build Notes:
......LOL J/K
