RB26 Shortblock Build Database
This is a sticky topic.
  • RB26 Shortblock Build Database
    Well, similar to the MOD Database, let's do one better and share the wealth of knowledge and more importantly, FIRST HAND EXPERIENCE.
    I find it extremely difficult to believe that there are so many engines being built in Canada, yet there is almost NO information on them that people are willing to share DIRECTLY in terms of their individual experiences. This is a cause for not only confusion, but frustration by some considering the banter on the Internet in regards to BAD PARTS, BAD SHOPS etc. Let's hear it from the 'Horses Mouth' so to speak.
    I simply want to get to the bottom of most of the CRAP.
    It seems that someone ALWAYS has a friend of a friend that has killed an N1 Oil Pump - BUT NEVER THEMSELVES.
    It also seems that someone has also been told of Eagle Rods failing - but never experienced it themselves.
    Let's set the record straight and put the Internet Pollution to bed once and for all.
    THIS IS NOT FOR JDM BUILT MOTORS - JUST CANADIAN & AMERICAN...as in, NOT BUILT in Japan.
    So........
    COPY>-----------------------------------------------------------------
    RB26 Engine Shortblock Build Database:
    Block:
    Rods:
    Rod Bolts:
    Pistons:
    Pins:
    Crank:
    Main Bearings:
    Rod Bearings:
    Oil Pump:
    Water Pump:
    Timing Belt:
    Cradle/Main Fasteners:
    Harmonic Balancer:
    Special Build Notes:
    Machine Shop:
    Shortblock Assembly By:
    Crank Prep:
    Rod Prep:
    Balanced Rotating Assembly?:
    Block Prep:
    Torque Plate Used ?:
    Special Modifications to Parts:
    Any other points to add:
    Post Build Notes:
    Specific Part Failures:
    Overall Shop Experience:
    -----------------------------------------------------------------<PASTE
    I will use my imaginary friend 'Allan' as a starting Point to show as an example of using the above template.
    Block: Early R32 Rb26
    Rods: Eagle H-Beam Forged
    Rod Bolts: ARP 2000
    Pistons: CP 87mm Forged
    Pins: CP
    Crank: Brand New R34 Nissan OEM RB26
    Main Bearings: ACl Race Series, STD
    Rod Bearings: ACl Race Series, STD
    Oil Pump: Nissan N1
    Water Pump: Nissan N1
    Timing Belt: Greddy
    Cradle/Main Fasteners: OEM Nissan RB26 Bolts
    Harmonic Balancer: ATI 500HP, #918599
    Machine Shop: Bob's Machine Shop, Imagination Land City, Alberta
    Shortblock Assembly By: Bob's Machine Shop
    Crank Prep: Polish only, as it was new (no collar required, no turning)
    Rod Prep: Bearing Clearencing Only
    Balanced Rotating Assembly?: YES
    Block Prep: +1mm over bore, tank, magnaflux, line hone, Oil gallery mods, Tomei Oil restrictor.
    Torque Plate Used ?: YES
    Special Modifications to Parts: Bearing Clearencing/Blueprinting only, None otherwise, all bolt in
    Any other points to add: My Friend's, Sister's, Husband's, Boss's, daughter told her neighbour that people kill N1 Oil Pumps because they are too cheap to buy a balancer.
    Post Build Notes:
    Specific Part Failures: None
    Overall Shop Experience: Good
    Block: '91 R32 RB26DETT 148,000kms
    Rod Bolts: ARP 2000
    Pistons: Wiseco Forged 87mm
    Pins: Wiseco
    Crank: Stock Polished
    Main Bearings: ACL Race Series STD
    Rod Bearings: ACL Race Series STD
    Oil Pump: Tomei
    Timing Belt: Tomei
    Harmonic Balancer: ATI Race
    Machine Shop: Alec's Automotive (Rob) Vancouver B.C.
    Shortblock Assembly By: Alec's Automotive (Rob) Vancouver B.C.
    Crank Prep: Polished, collared & balanced
    Rod Prep: Bearings spec'd, rods balanced
    Balanced Rotating Assembly?: Yes (all rotating parts sent out and balanced together)
    Block Prep: Decked, +1mm over bore, tanked, magnafluxed, line honed, Oil gallery mods, Tomei Oil restrictor.
    Torque Plate Used ?: No
    Special Modifications to Parts: All clearances spec'd, balanced & blueprinted
    Any other points to add: Nope
    Post Build Notes:
    Specific Part Failures: Timing belt idler bolt broke raising hell internally.
    Overall Shop Experience: Rob @ Alec's Automotive is a wizard machinist...
      no longer relevant
        Block: OEM 1990 05U
        Rods: Eagle
        Rod Bolts: ARP 2000
        Pins: The ones that came with the Wisecos.
        Crank: OEM, 0.25MM Under, Crank collar fitted
        Main Bearings: ACL Race series, 0.25mm oversize
        Rod Bearings:same
        Oil Pump: N1
        Water Pump: OEM
        Timing Belt:Greddy
        Cradle/Main Fasteners: Reused OEM
        Harmonic Balancer: Reused OEM (for now, plan on fitting the ATI one at some point this winter)
        Cryo-treated rods, piston rings, piston pins, bearings, crankshaft, oil pump gears, all important hardware.
        By silver bullet machine in windsor, ON
        Machine Shop: R/T Automotive machine, leamington, ON
        Shortblock Assembly By: Terrh, under supervision from R/T
        Crank Prep: Not sure of the shop (machine shop sent it out), ground 0.25mm under, new oil pump drive put on.
        Rod Prep:
        Cryoed, that's it.
        Block Prep: Hot tanked, bored 0.5mm over, decked, honed as per piston insturctions, malibusst oil restrictor, ARP head studs.
        Torque Plate Used ?: no
        Special Modifications to Parts: Rings gapped slightly on the "large" side per instructions for "high boost/nitrous" applications.
        Post Build Notes:
        Specific Part Failures: None yet! 7 months and 23,500KM as of this post.
        Overall Shop Experience: R/T machine does awesome work!
        EDIT: Engine failed july 10, 2009 with ~40,000KM on it. OEM valve guides which weren't replaced during the rebuild cracked and some pieces dropped into the comubstion chambers, damaging the cylinder walls and quench pads on the head.
          Originally posted by Terrh View Post
          BEST. IDEA. EVER..
          You mean, SINCE my 'Engine Mods DB' sticky that is ......LOL J/K
          Anyways, Guys, I just wanna say thanks for giving this idea, once again, such a WARM WELCOME......
          This will help many people including my greedy @ss little self
          ...anything to BETTER the community as a whole.
          I also feel that in the case of FAILURE - this will allow us to BETTER ADDRESS PROBLEMS and help people find out WHERE the problem may have begun......kinda like everyone's own personal 'build road map' of sorts.....
          Allan
            Block: 91 Block with 130xxxkm
            Rods: Eagle H beam Forged
            Rod Bolts: ARP 2000
            Pistons: Wiseco 87mm Forged
            Pins: Wiseco
            Crank: New OEM R33/34
            Main Bearings: ACL Race STD
            Rod Bearings: ACL Race STD
            Oil Pump: JUN
            Water Pump: N1
            Timing Belt: Tomei
            Cradle/Main Fasteners: OEM/ARP
            Harmonic Balancer: ATI Street Version
            Machine Shop: BEL Engine Services,Edm,AB 780-465-3586 (ask for Les)
            Shortblock Assembly By: BEL Engine Services
            Crank Prep: Tanked,Magnaflux,Polished, Balanced
            Rod Prep: Balanced
            Balanced Rotating Assembly?: Complete assembly Balanced & Blueprinted
            Block Prep: Tanked,magnaflux,1mm overbore,Honed,Oil restrictor
            Torque Plate Used ?: Unsure was told they used some type of a plate
            Special Modifications to Parts: PTD oil return line,Oil pan sump holes enlarged
            Any other points to add: Have at least an extra 25% above what you budgeted
            Post Build Notes:
            Specific Part Failures: #5 cylinder valve failure, bent *(stock valves running 25psi boost)
            Overall Shop Experience: Very good experience
            ........Nothing but Good Times........
              If you guys wanna delete this cause its not a RB26 go ahead
              But I thought it still qualifies
              RB30 Engine Shortblock Build Database:
              Block:RB30
              Rods:Argo
              Rod Bolts:ARP
              Pistons:Custom Wisecos with skirt and dome coated
              Pins:22mm
              Crank:OEM
              Main Bearings:ACL
              Rod Bearings:ACL
              Oil Pump:Trust/Greddy
              Water Pump:N1
              Timing Belt:Gates T291
              Cradle/Main Fasteners:ARP
              Harmonic Balancer:Ross
              Machine Shop:GB Performance http://www.gordbushperformance.com/about.htm
              Shortblock Assembly By:Myself
              Crank Prep:Polished,filleted,Tapped oil passages,drive collar installed
              magnaflux
              Rod Prep:Balance Checked big & small ends
              Balanced Rotating Assembly?:yes
              Block Prep:tapped all oil passages, casting flash removed,enlarged oil returns,
              blocked oil pickup internally, resized head bolt threads,
              resized oil pan adapter bolt threads
              Torque Plate Used ?:Yes
              Post Build Notes:
              Specific Part Failures:My 26 never failed but I can confirm that the oil pump bolts at
              the rear of the pump do come loose.
              Overall Shop Experience:I've been to a number of different shops and had horrible experiences
              Gord Bush, I have to say has been a shop to have all my work done at.
              Favorites
              lucky_cefiro
              you\'re not listening
              entelijint
                Block: 1990
                Crank: R32 Early w/JUN Collar
                Rods: Pauter 4340 Billet
                Rod bolts: ARP
                Main Bolts: JUN
                Main Bearings: ACL Coated
                Rod Bearings: ACL Coated SR20
                Oil pump: Nismo
                Water pump: N1
                Rod prep: Big ends modified to accept SR20 Rod bearings. Big ends were not properly round, so had to be re-honed.
                Block prep: Tanked, Manafluxed, Bored, honed, oil restrictor installed
                Balancer: ATI R32 large
                There are 10 kinds of people in the world: those who understand binary and those who do not.
                  Block: 91 RB26DETT
                  Rods: Eagle ESP H-Beam Forged
                  Rod Bolts: ARP2000
                  Crank: OEM Remachined
                  Main Bearings: ACL
                  Rod Bearings: ACL
                  Oil Pump: New OEM
                  Water Pump:OEM
                  Timing Belt: Greddy
                  Harmonic Balancer:OEM
                  Headgasket: Cometic MLS
                  Machine Shop: D&W Custom Engines (Calgary)
                  Shortblock Assembly By: D&W (Adam)
                  Balanced Rotating Assembly:Yes
                  Block Prep: Hot Tank,Flatdeck,Allignment, Bore & Hone
                  Post Build Notes:
                  Overall Shop Experience: Great
                    Block: r33 rb26dett
                    Rods: EAGLE
                    Rod Bolts: ARP2000
                    Pistons: MAHLE 87mm
                    Pins: MAHLE 21mm
                    Crank: R33
                    Main Bearings: acl race
                    Rod Bearings: acl race
                    Oil Pump: N1
                    Water Pump: N1
                    Timing Belt: Greddy
                    Cradle/Main Fasteners: ARP
                    Harmonic Balancer: ROSS metaljacket
                    Machine Shop: http://www.overbore.com/
                    Shortblock Assembly By: me
                    Crank Prep: polish , done by overbore
                    Rod Prep: done by overbore
                    Balanced Rotating Assembly: yes , done by overbore
                    Block Prep: Hot Tank,Flatdeck,Allignment, Bore & Hone done by overbore
                    Torque Plate Used : yes , done by overbore
                    DrifterToyz Team
                    AV FABRICATION (514) 885-2884
                    TK RACE HEADS (514) 920-0094
                    Runing me Broke RB power FTMFW !!!
                    HELLAFLUSH offset is everything !!!
                      Block: New N1 Block (24U) 11000-24U00
                      Rods: Greddy/Carrillo - Rod set GRD-13520761
                      Rod Bolts: Greddy/Carrillo
                      Pistons: CP - 86.5mm Forged Pistons SC7310
                      Pins: Greddy/Carrillo
                      Crank: New OEM
                      Main Bearings: Nismo - Main Bearings x 6 12207-RRR40,Main Thrust Bearings x 1 12261-RRR40
                      Rod Bearings: Rod Bearings x 6 12110-RRR40
                      Oil Pump: Tomei
                      Water Pump: N1
                      Timing Belt: Tomei
                      Cradle/Main Fasteners: ARP - Main Studs Oversized ARP-202-5406
                      Harmonic Balancer: ATI 1000hp Street
                      Oil Pan: Tomei Oversized
                      HeadStuds: ARP
                      Machine Shop: Vinny Ten Racing
                      Shortblock Assembly By: VTR
                      Crank Prep: Dont Know
                      Rod Prep: Dont Know
                      Balanced Rotating Assembly?: Dont Know
                      Block Prep: Dont Know
                      Torque Plate Used ?: Dont Know
                      Any other points to add: Bought ready built from a guy in Texas, Built for his drysumped 1200hp drag car. not run yet.
                      Post Build Notes:
                      Will update when i get it all together and running.
                      Trust T618Z,Carrillo Rods,CP Pistons,Tomei 280 10.8 lift ProCams, Tomei Spec C Springs, N1 Block, ARP, ATI, ATL, Bosch 044,Sard 800cc,PFC,Z32 etc.......
                        What's this about Eagle Rods failing ? It seems that everyone who's posted so far is using Eagle Rods ... Anybody experience anything bad with them ? (I also am looking at using Eagle Rods, hence the curiousity). Sorry if this is off topic.
                        Corey.
                          Bit late to the party. Built a couple months ago
                          Block: 05U supposedly early block
                          Rods: Tomei
                          Rod Bolts: ARP L19
                          Pistons: CP
                          Pins: CP
                          Crank: New R33
                          Rod Bearings: Nismo
                          Oil Pump: Tomei running 2 shims
                          Water Pump: N1
                          Timing Belt: Tomei
                          Shortblock Assembly By: Me
                          Crank Prep: Polished, measured, balanced
                          Rod Prep: Measured, balanced
                          Block Prep: Bubble bath, magnaflux, 1mm overbore, Honed, Crazy cool paint job
                          Torque Plate Used ?: Yes
                          Special Modifications to Parts: accidentally modified my oil orifice to 1.25 , Have a Greddy oil pan extension
                          Any other points to add: Rings are a huge PITA
                          Post Build Notes:
                          Specific Part Failures: Hasn't ran yet
                            Corey.
                            Eagle rods are cheaper than most. Supposedly rated up 1500hp. I wanted to go with Carrillo SA rods but was suggested that eagle was fine for my goals of sub 800whp. Anything can fail. don't stop just cause someone says it. Tomei oil pumps have broken before.
                              build
                              Block:05u
                              Rods:carillo
                              Rod Bolts:arp
                              Pistons:cp upgraded
                              Pins:cp upgraded
                              Crank:new n1 r32 r33 r34
                              Main Bearings:acl
                              Rod Bearings:acl
                              Oil Pump:nismo
                              Water Pump:n1
                              Timing Belt:tomei
                              Cradle/Main Fasteners:arp
                              Harmonic Balancer:ati 1000hp
                              Machine Shop:Taylor and son in brampton
                              Shortblock Assembly By:same
                              Crank Prep:all brand new
                              Rod Prep:balanced
                              Balanced Rotating Assembly?:ero grade
                              Block Prep:bored .5
                              Torque Plate Used ?: nope
                              Special Modifications to Parts: ferrea valves+1 and locks, tomei springs cams gears, cometic head gasket and tb to head gasket, hks exhaust gasket, tomei expreme manifolds, hks outlets, tomei intake to tb gaskets, greddy intake, tomei +1 buckets, arp studs all around
                              Any other points to add:greddy catch can and piping 5 inch intercooler, and greddy radiator, nismo thermostat, tomei oil restrictor, takedo gaskets, nismo fuel pump and regulator, tomei fuel rail, all braided fuel lines
                              Post Build Notes:
                              Overall Shop Experience:Larry taylor can build a motor great guy to deal with and amazing port work thanks again
